Need advice buying pistons, rings, rod bolts
Well, my 62k mile original short block in the '94 is starting to die. All the years of racing have caught up with me. It is not knocking, but I'm getting a large amount of blow-by through the valve cover breathers and the car has started running about 3 tenths slower at the track.
We are going to start tearing it down in the next couple days and I'm going to step up to forged pistons, chromoly rings, and ARP rod bolts. The motor will see an occasional 100 shot of juice, so I want to step up the components.
Questions:
1. What pistons do you recommend and who should I buy them from? (good prices and service)
2. Is it possible to slightly step up the compression with out getting custom pistons made? I'd like to just up it a half-point to 11:1, but a lot of shops will not have those "on the shelf". In other words, who would have 11:1 LT1 pistons in stock? I know the old "Impala SS head gasket trick" but would rather just get a very slightly domed piston.
Thanks in advance.
Questions:
Thanks in advance.
Originally Posted by TWS
Well, my 62k mile original short block in the '94 is starting to die. Questions:
Thanks in advance.
Thanks in advance.
Yep. Just got the whole parts package laid out with a machine shop in Waco. They get quality parts at excellent prices, and Speed Pro forged pistons are exactly what we arrived at.
I'm having the block sent out to do a line bore, convert to 4-bolt main caps, and do a .030 cylinder overbore.
This motor should rock!
I had good luck with Diamond Pistons. They had what I needed on the shelf and were very helpful. I give them a try.
www.diamondracing.net
Moderator
My buddy bought the diamonds on his LS1 and they end up needing some work to get it right on the height. A lot of guys are using the GM Performance parts crank, its a forged crank with the same stroke as stock. Brady used one on his built motor that handled a lot of boost. It retails in at what a Forged Eagle Crank would cost and availible from any GM dealer, I'm sure Dal or Jason Cromer could get you a good deal on it.
I would seriously suggest going with a cast 383 crank instead of sticking with the stocker.
Ther price for pistons/rods will be esentially the same, machine work difference will be only around 100 bucks, and you can pick up cast 383 cranks (LT1/1pc rms style) for around 300 bucks. It would be well worth it.
