Where is best place to buy a lt1 383 stroker kit ?
Old 05-23-2009, 05:41 PM
madmike9396's Avatar
Default Where is best place to buy a lt1 383 stroker kit ?
As the title says, Thanks to anyone with info
Old 05-23-2009, 06:28 PM
monster81's Avatar
http://www.tpis.com/index.php?module...ing+Assemblies
Old 05-23-2009, 07:29 PM
thanks, 3100 bucks damn seems a lil pricey to me may not be tho idk
Old 05-23-2009, 07:50 PM
bombebomb's Avatar
They do not even say what you are buying besides a kit, with god knows what in it. Even if they will tell you they should have it listed.
Old 05-23-2009, 07:59 PM
ARCTIC '00's Avatar
Well first of all, what are your intentions with the car? How far are you planning to go with it. If your only planning 'the usual' H/C LT1 setup and nothing more than the kit above from TPIS would be overkill. They have budget LT1 kits starting at under a grand, you could substitute for forged pistons and be good to go.
Old 05-23-2009, 08:01 PM
yeah im just wanting something that will handle the le2 setup with about 150 shot.
Old 05-23-2009, 08:08 PM
ARCTIC '00's Avatar
Well in that case yeah forged is the way to go. You'll be over 500rw with a LE2 + 150-shot.
Old 05-23-2009, 08:40 PM
bombebomb's Avatar
At least a forged piston, I would go forged rods also, stock crank "could" handle that, but why change the crank?
Old 05-23-2009, 08:51 PM
FlamingChicken's Avatar
id imagine it would be real hard to get a 383 with stock stroke I like my lunati stuff though. a bit pricey but good ol made in the usa.
Old 05-23-2009, 08:58 PM
2XR95Z28's Avatar
www.advancedinductions.com
Old 05-23-2009, 09:58 PM
RamAir95TA's Avatar
Originally Posted by 2XR95Z28
Correction (in case he can't figure it out) -
www.advancedinduction.com
Old 05-23-2009, 10:11 PM
do you think the budget AI 355 will handle the le2 and a 150 shot ?
Old 05-23-2009, 10:45 PM
bombebomb's Avatar
Ai Budget 355cid LT1 Rotating Assembly Package:
# Utilizes Stock 3.48" Stroke Crankshaft (Not Included!)
# Compstar Forged 4340 H-Beam Rods
# Mahle Forged Pistons (-5cc or -16cc)
# Mahle Plasma-Moly 1.5/1.5/3mm Ring Package
# Mahle Steel Pins & Wire Locks
Compstar makes good quality budget parts in most peoples minds including mine, mahle pistons are also highly rated across the board.
So you get rods, pistons, and rings for $1195
Compstar rods are $600 or around there alone, not sure on the price of Mahle pistons etc, so may look into that.
Old 05-24-2009, 01:27 AM
2XR95Z28's Avatar
Opps, thanks RamAir95TA lol. AI Rocks though....
Old 05-24-2009, 09:58 AM
damn why dont they include the crank ? Thanks 4 the info guys keep it coming
Old 05-24-2009, 10:09 AM
z28rob18's Avatar
i think the budget 355 kit would be good for the le2 and 150 shot. not to pricey you just use your stock crank. or buy the forged 355 kit.
Old 05-24-2009, 11:04 AM
Thats what i was thinking but idk trying to weigh out all my options on a budget tho
Old 05-24-2009, 11:07 AM
the 355 would turn up quicker than a 383 wouldn't it because of the shorter stroke correct ?
Old 05-24-2009, 11:44 AM
z28rob18's Avatar
i believe so depends on the cam i think. but you may be better lookin for a nice shortblock.
Old 05-24-2009, 12:39 PM
halucinator's Avatar
Cranks can get pricey quick, forged especially. I think they are just going to have you utilize your own stock crank.
Quick Reply: Where is best place to buy a lt1 383 stroker kit ?
