Cam bearing!?
Old 05-23-2009, 11:07 PM
red-_-z28's Avatar
Arrow Cam bearing!?
So im at the point of installing the new bearings but when i took the others out i didnt remember to note where the holes in the bearings went.
I found on the new bearings number.. it went 1, 2, 2, 3, 3, 4
so im assuming the 2 and 3's are the same but i dont know where they go.
And where are the holes suppose to line up at?!
Thanks
Old 05-24-2009, 12:08 AM
the_merv's Avatar
I always have the Machine Shop do mine..
Old 05-24-2009, 12:13 AM
bombebomb's Avatar
Same here, they got the right tool to do it with lol, hopefully someone chimes in and answers your question.
Old 05-24-2009, 12:21 AM
harley6964's Avatar
whot is the bigest cam you can use without useing a stall on a bilt 350???
Old 05-24-2009, 06:42 AM
the_merv's Avatar
I do know that the holes line up with the Oil Plumbing Holes in the Cam Journals.
Old 05-24-2009, 07:34 AM
smb72's Avatar
You have yourself a small problem now that you did not mark each cam bearing. The outside diameter is different on each bearing. I beleave the last one is the smallest with 4,3,2,1 by diameter. Also the oil holes should be in the 5 oclock postion
Old 05-24-2009, 10:49 AM
red-_-z28's Avatar
many people told me that they dont line up because you would lose oil pressure
Old 05-24-2009, 01:37 PM
red-_-z28's Avatar
come on guys...does anyone know?
Old 05-24-2009, 03:06 PM
My95Z's Avatar
Your new cam bearings should have a # or code on them, then you reference that code with where it tells you to put it. The bearing with 2 holes goes in the front, but off the top of my head I can't remember the other orders.
It doesn't really matter which way the bearing is installed, b/c the oil will travel underneath the bearing in the block through the channel (don't remember tech term) and come out the hole, but I always install mine at 5 o'clock.
Quick Reply: Cam bearing!?
