LT4 water pump question
Old 05-24-2009, 02:21 PM
jwindbigler's Avatar
Default LT4 water pump question
There's a connecting piece that connects the 2 male ends (one from the output of the block, and the other from the water pump) and I need to know how to get that piece off. I am changing out my water pump and need to get that piece off so I can finish the job. Thanks
Old 05-24-2009, 03:44 PM
YodiBrodi's Avatar
give it a good pull. it's not connected by anything but maybe an o-ring
Old 05-24-2009, 11:08 PM
So its not pressed on or anything? Just on there good.
Old 05-24-2009, 11:21 PM
litch2004's Avatar
Just on there good. I just put a screw driver in there and just twisted the screw driver and it pushed it right off.
Old 05-29-2009, 09:32 PM
I put some WD40 on it, and let it sit for a while, but some channel-locks on it, and wiggled it, and it came right off. Thanks
Old 05-29-2009, 10:02 PM
shbox's Avatar
Grease it and use new o-rings when you reinstall it.
Old 05-31-2009, 08:34 PM
Already done. The admin can go ahead and close this thread. Thanks for your help guys.
Quick Reply: LT4 water pump question
