Some factory heads better than others?
374's and 643's are the better heads for porting because they have more meat on them to take off. They dont flow as well as the later heads or the 561's in stock form but flow more in ported form.
dont make much sence to say they can be ported "more"
if the coolant passages are in the same area along with the rest of the head desgin similar.... then all it is just more material to be taken off that was already removed on the later heads. The limits would be just the same and couldn't be taken "FURTHER" than the next head could...
To me just sounds like there is more material to remove to get the same flow...
its not all about coolant passages. I believe they have less pushrod clearance therefor can be opened up more in the intake runner. There is no doubt that they are better for porting. Lloyd elliot recommends these heads when he ports them for his LE packages. A couple years back he was buying them all up.
That is an internet myth. Every set of 561 heads that I have flowed was down when compared to 374/643 heads. the 561's were also cast with less aluminum in them as a cost cutting measure by GM. If you have actually seen a set of 561's that flowed well please post up what you have seen.
Your assumption is that a bigger hole is better. Lots of heads have been ported with that mentality. Doesn't make it right.
True experts manipulate airflow to make it move smoothy rather than just making the hole larger.
I know of one case where a shop removes just 7cc from an intake runner and somehow it out performs ALL the competition in catagories from drivability to max and average power despite the competition removing more material. It is about how the air moves, NOT how big a hole you give it.
Size is EVERYTHING No I'm just kidding. Power from head flow is all about air velocity. That's why some head porters out there are making tons of power with a not so large intake runner size. Like Dwayne said just because you see a bigger port doesn't mean it's going to make more power than a smaller port done right.
This is where Lloyd comes in though...he obviously like the older head for porting for some reason. And he knows what he is doing and in terms of what makes power based on the results posted by numerous customers of his. I think bigger isn't better for the sake of being bigger, but in each particular style of head/case having bigger ports may make the difference for the air flow where as others don't need bigger so much as a tuned flow to make more power. I would imagine that the bigger ports when utilized properly make more power...probably why Lloyd wants them over the others. Not that more than enough power for most people's application cannot be achieved using the "561" heads. Just for max gains, he wants the other ones.
