SBC Guideplates
Old 06-02-2009, 10:42 PM
gregrob's Avatar
Default SBC Guideplates
Any reason they wont work?
Old 06-02-2009, 11:00 PM
SoxXpupPeT's Avatar
nope dont think so
Old 06-02-2009, 11:01 PM
gregrob's Avatar
You dont think, there's a reason they "wont" work?
LOL
Too many double negatives.
Old 06-03-2009, 07:28 AM
shbox's Avatar
SBC guideplates don't have the same spacing as what is needed for LT1s. You will end up with several cylinders with skewed alignment.
Suggestions:
GM p/n 14011051 (8 needed) (good idea to check them for hardness)
Trickflow Part # 30400623-8
or adjustable guideplates
Old 06-03-2009, 11:11 AM
Low N Slow's Avatar
I tried the GM and the Trickflows and neither one was right for my heads, I ended up using the Isky adjustables.
I have a set of the GM ones for cheap if you want to try them.
Old 06-03-2009, 11:19 AM
ss.slp.ls1's Avatar
What heads were those?
I have TF guideplates on my stock heads and they work fine.
Old 06-03-2009, 11:27 AM
tonskiguy's Avatar
I took some SBC's and hack sawed 90% of the way through, and spread the slot spacing as required. Then I bridged the cut with a weld and bolted them up. It seems like this will work well.
Old 06-03-2009, 01:50 PM
gregrob's Avatar
Suggestions:
Thanks a lot Rob
Shoot me a price.
Old 06-03-2009, 02:55 PM
mdacton's Avatar
I have checked the trick flow vs. comp regular sbc and there was no difference at all....
Old 06-03-2009, 03:44 PM
shbox's Avatar
By the naked eye, the spacing looks different to me. Even a small amount is enough to make a difference.
Old 06-03-2009, 08:40 PM
gregrob's Avatar
hmmm.
Old 06-03-2009, 09:05 PM
94Pontiac's Avatar
im running comps...no issues
Old 06-03-2009, 09:10 PM
mdacton's Avatar
well I had them both in my hand and stack them on top of each other...they are the same....
I used Isky before too. they are a pain in the *** b/c they move when you tighten the stud. its a pain. I just used some comps I had and they are fine
Old 06-03-2009, 09:43 PM
shbox's Avatar
Here is a comparison to some I had before from the old Combination Motorsports vendor. I think they were probably Comp plates. They did not align all cylinders properly. The spacing difference was also detectable in a side by side or stacked comparison to the GM plates.
http://shbox.com/1/guideplate_compare.jpg
Quick Reply: SBC Guideplates
