What do you think it will run???
I have a 97 ram air LT1. It weights 3620# without driver. Its a convertable. The short block is all stock with 113,000 miles. Heads are fresh ported. I forgot the cam number but it is ground on a 113 and has 579int. and 583exh. A 3200 vig. converter and 30# injectors. Pacesetter long tubes and no cats with a flowmaster. Other than that the car is 100% stock. Now for the what will it run. I have run the car in decent weather as is with a 2.73 stock rearend. 60ft. was a 1.92 "on a regular radial with no tire spin" and a 13.17 et@105mph. Now I have purchased a 12bolt that im going to put in to the car with a 3.73 gear. More than likely I will need a tire at that point but im looking to get an idea on what I should pick up from the gear in ET and mph. What do you guys think it should do if I ran it in the same conditions as last weekend when I took it?
Sure that sounds great. How about everyone put in a $10 bucks to guess what it will run. After I collect 100 entrys we will go to the track and I will post the times and pay out the $100 bucks sound good??? I like that idea.
