oil presure
oil presure
hi i had read that some oils if you have low oil pressure are good to help bring it up? Like mobil 1 10w30?? does it make a difference if its synthetic or not? and if not what kind? Sorry if this is a dumb question, and thanks in advanced for any help
ohh my bad i just started using mobil 1 10w30 sorry i ment other types.. i had just heard thicker oils are good if you have low oil pressure.. mines not to it hovers right at a 1/4 i think its 20psi but sometimes will drop just a little below it... so i was just making sure... mayb something like 10w40? i live in houst texas though so it gets hot!
M1 thins too quick I've had crap psi for awhile now and am happy with my PP 20w40 no engine noise noticed a good increase in psi and stays that way for a good 2.5k where as m1 would start to creep down around 1.5 or so
And if you're having to use oil that thick just to keep the pressure within stock limits, something is wrong. A thicker oil also puts more stress on the oil pump - something to consider.
i ran my car for along time with skeptical oil psi. i ended up burning up a set of rockers i had on the car when i built up my engine i went with a high psi standard volume melling. i love 35 psi hot idle
if your not to comfortable with oil psi that low (neither was i) you could always install a GM white spring to kick the psi up at idle.
