Which opti distributor do I need?
Old 06-24-2009, 12:57 PM
Black94Z28's Avatar
Default Which opti distributor do I need?
Looking at the summit catalog and they have an gm performance parts opti for 93-early 94 and a opti from late 94-97, how can I find out what I have on it now? The current cap is a MSD cap. I know one is vented and non vented, so where should I look for the vent? just want to make sure I know for sure how to tell them apart. I heard if you get the wrong one you need to change the timing cover. Thanks
Old 06-24-2009, 01:07 PM
ss.slp.ls1's Avatar
Don't get your opti from Summit. Get it from "thepartsladi" on Ebay.
You need a '93-'94 optispark. It is non-vented but you can also order a MSD cap & rotor and that basically converts your opti to vented which helps keep moisture out of your distributor. Just be sure to thread lock the rotor screws when you put the MSD cap & rotor on.
Old 06-24-2009, 03:40 PM
96capricemgr's Avatar
The catalogue confusion on the optis is because in 94 the f-body and Vette got the early "unvented" setup but the b-bodies and Fleetwood(d-body) got the later vented setup.
There was no midyear change, it is a difference in model that the catalogues just can't get right.
Old 06-24-2009, 06:54 PM
Z28Camaro30Ann's Avatar
X2
Go with AC Delco from someone more reliable when going for an Opti...just upgrade to the vented MSD Cap/Rotor
Old 06-24-2009, 07:37 PM
DriftR's Avatar
What he said ^ (to the letter)
Old 06-27-2009, 05:30 PM
Black94Z28's Avatar
Here is a pic of my opti, not sure what the previous owner did with it. Not sure if he put a new opti on or just the cap. Not sure if this will help or not. Also the little nipple port next to the harness plug was never hooked up to anything, not sure what thats for. Anyways...
Old 06-27-2009, 09:29 PM
That is not where the vent is on a stock vented setup. I would guess that is the MSD vent retrofit for the "unvented" style.
Old 06-27-2009, 09:51 PM
It has definately had the MSD conversion but I cant tell if that opti itself is stock or not. That top nipple you see is one of the 2 vent lines. one runs from the opti to the middle of the driver side on the intake manifold, just under another vaccum hose... The other vented line runs from the opti to a small hole in your intake elbow. They are there to create a small vaccum inside the opti to help it vent better and keep moisture out. all you need is a small rubber hose about 24" long or so and stick it on there.
Old 06-27-2009, 10:19 PM
The MSD opti has a timing adjustment screw that would be visible from that angle. It is not there so it is a stock base.
Old 06-27-2009, 11:46 PM
So there ya go. You have a stock opti with the MSD cap/rotor conversion. You need to get a hose on that nipple though and try and hook it to your intake elbow to help vent that thing.
Are you wanting to upgrade your opti? Just know what your running with? Or what are your plans for it???
If that opti is not messing up, and the cap/rotor are good to go, leave it be. If you wanna upgrade....I used the MSD distributor, but there are a few options you could take.
Old 06-28-2009, 08:00 AM
flyinZ's Avatar
Yep, you need the 93-94 Opti, not the 94-97' unit.
Whats wrong with an GM opti from Summit?
Old 06-28-2009, 08:04 AM
Black94Z28's Avatar
I just wanted to make sure which opti I had. Wasnt sure if I had the vented or non vented one. My car kept running rough and died on me when i was going 40 mph, then wouldnt start for a couple hours, fired up ran, shut it off, tried again and kind of dieseled for a second or two and then white smoke came out of the intake tube, leaving me to guess its the opti
Old 06-28-2009, 10:35 AM
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
Unless there has been a cam swap on your car, you would need the unvented type drive, which is a splined shaft.
Old 06-28-2009, 10:43 AM
RamAir95TA's Avatar
If that's the vented conversion, where is the other fitting? In order to draw in vacuum there needs to be both an inlet AND an outlet.
Old 06-28-2009, 10:44 AM
flyinZ's Avatar
The inlet port is at the top and the outlet port is at the bottom of the cap, I believe.
Old 06-28-2009, 11:56 AM
yeah, the outlet is a larger port, almost looks the same as where the coil wire goes into the opti on the bottom driver side of the opti...
Quick Reply: Which opti distributor do I need?
