ram clutch or spec 3 clutch
ram clutch or spec 3 which one is better what do yall think my friend should buy for his lt1 camaro z28 he has 410 gears ported heads and cam, and full exhaust
I personally like the spec clutches allthough I've never had any experience with the Ram clutches. Some people have issues with spec but typically it's people who don't break it in right and/or don't know how to correctly drive an M6. I've had a spec 3 and it was super stiff but I really liked it. I've got the same clutch for sale, along with a billet steel spec flywheel. The clutch and flywheel have 29 miles on them and look great. Tell your friend to check this thread. https://ls1tech.com/forums/non-lsx-p...much-more.html
ill let him know about the clutch and flywheel
i have a ram hd clutch in my car and its anything but stiff... closer to what stock is like... but i have no complaints about it.. .mine has oil contamination on it and it still holds enough to burn out big 315's out back....
We run the ram clutches in our stuff. The quality is top notch. If you ask twenty guys which clutch to run you'll get twenty different answers. The best thing you can Do is talk to somebody at RAM and SPEC and be completely honest about combination, torque requirements, type of driving and driving style. They will help you pick out the best clutch for your application.
he wants a street and strip clutch..i know that the ram and the spec 3 clutch r both good and not that expensive
he was leaning more to the ram clutch but i think hes gna go with the spec 3 instead im not too sure he might change his mind
RAM IT!!! i'm pushing 500rwhp's and mine is holding sooollliiiid!!
http://www.lmperformance.com/16167/2.html
i think i might get it since i was thinking that or spec stage 3+
