Coil Question
Old 07-06-2009, 08:14 PM
Veganomics's Avatar
Default Coil Question
Hey Guys , I have a 95 Z which now has a 96 Harness. basically I switched to an auto , and the harness is from a 96. I bought a new coil (single plug MSD 8231 for the 96 harness) however the coil has no tower on it for the coil wire. Does someone have a pic of a 96 coil wire, or a suggestion as to what kind of coil wire I can buy or make? OR, is there a tower that can be bought for this coil?
Thanks
Old 07-06-2009, 10:37 PM
shbox's Avatar
LS1Tech 10 Year
The 96-97 coils uses a terminal that is the same as the terminal on the opti end (so, your old coil wire won't work). It has to have a place to plug in the coil wire.
Old 07-07-2009, 12:08 PM
ss.slp.ls1's Avatar
Get a spark plug wire kit for a '96-'97. You can use the coil wire and toss the rest of the wires on a shelf in your garage. It never hurts to have a set of wires on the shelf anyways.
