Stock gears with stall?
A kid up the street from me just bought a 94 Trans Am and it has 2.73 gears but the guy that sold him the car also threw in a 3600 stall converter not installed. He knows I have 2 LT1s and he came down and knocked on my door and asked if it would help his car a lot if he put that stall in. I told him I would find out and let him know. I have never ran high stall with stock gears. I have always done gears first or both at the same time. Has anyone did just a stall and noticed a difference or get any better results at the track with just a stall and stock gears? I tried to tell him to get gears but he doesn't have the money right now.
I was able to drop off .6 seconds with a stall on my 00 trans am using 2.73 gears. With bolt ons it ran a 12.5 on street tires with a 1.8 60'
I know it's a different engine, but a stall will definately help.
With a 2.73 gear you will notice an improvement with getting a stall.
I went from 2.73 and stock stall < 3.73 and 3000 stall.
My god this thing is in the RPM range from no matter where I mash the stupid pedal. I think I get better gas mileage also because of the shorter gears allowing me to use less throttle to get up to speed.
There's some weirdness going on here.
I'm having a hard time understanding why a lower rear gear might be indicated before or necessarily simultaneous with a higher stall. It seems to me both mods work toward the same goal: more torque multipication on launch.
Now, a 3600 stall on a 2.73 rear gear might be a little extreme for a mostly stock LT1. Alternatively, it might be a great street/strip combo for a mostly stock LT1 to give it street talents plus decent gas mileage for a DD.
I continue to be curious about how street manners change with a high stall converter. Obviously, sticking with a 2.73 means it ain't a drag car, but whether it's a street racer or a DD might alter the decision.
I would like anyone who upped the stall without changing rear gears to chime in on how driveability changed...
Best -- Gary
Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. -- Douglas Adams,
Best -- Gary
I have got a Yank PY3400 with stock 3:23s, it is a lot of fun to toy around with and has great street manners. You have to give it a little more throttle input to achieve the same results when you are under your stall speed but once it engages it is a lot of fun
Best -- Gary
Best -- Gary
Best -- Gary
Best -- Gary
SS3600 with stock 3.23's with little to no difference in street manners. after u stomp it once u will forget all about the "street manners" the best way to describe it is when u kno u stop at a red light on level ground and u have to hold the brake pedal to keep the car from starting to move forward, well with my SS3600 the only difference is it will barely move forward if u arn't holding the brake, maybe a tiny bit but not like on a stock stall. but once u give it gas it feels like stock.
best way to describe it IMO. tell ur friend to take the stall, install it see how he likes it (which i gurantee he will) if not uninstall it and sell it lol (stalls are expensive!)
