Oh hey... stuck lifter.. yay
Old 07-10-2009, 08:02 PM
96blackz28's Avatar
Default Oh hey... stuck lifter.. yay
So anyone that had read any of my posts, i just got my car back together after sitting in a garage for 3 years. I have a stuck lifter on my drivers side, and car runs a little off, inseqeunce with the tick. Just put in some oil additive to see if i could free it but do not think ill have any luck. Im pulling valve covers tomorrow to look at things.. then maybe taking my intake off.. uggggh!! How common is this? And just would like to hear others experiences with this... Stock valvetrain by the way
Old 07-10-2009, 08:52 PM
ElkySS's Avatar
sounds like your cam is bad too. you should replace it while ur in there.
LS7 lifters are awesome btw
Old 07-11-2009, 12:18 AM
ZachsBlack94Z28's Avatar
put a monster from AI in it.....AI=ftmfw
Old 07-11-2009, 12:23 AM
ElkySS's Avatar
^^ lol
Old 07-11-2009, 02:05 AM
96blackz28's Avatar
you guys are comedians... no.. car does not need cam.. has 142k on motor. Pullin valve cover tomorrow, will let you kno
Old 07-11-2009, 07:43 AM
ElkySS's Avatar
every motor needs a cam. if thats the case, find a lower millage motor and swap it. dont even bother trying to fix this one.
Old 07-11-2009, 09:04 AM
96blackz28's Avatar
Well new cam yes if lobes are worn. Have a 383 in works man, just tryin to keep this going till thats done. Just saying stuck lifters suck ***.. but seems no one cares
Old 07-11-2009, 10:01 AM
WYATT318MOPAR's Avatar
You actually think the lifter is stuck compressed of just has some debris in it causing the tick? you might try to let the car idle with either some kerosene or transmission fluid in the oil that is a good way to clean out trash that has built up inside an engine over the years specially one with that kind of mileage. Worth a shot before you go tearing the intake and valve covers off. Worst it can cost you is an oil change which you will have to do either way. Good luck with things
Old 07-11-2009, 10:08 AM
96blackz28's Avatar
Yea, i put in some JB engine treatment, i got from summit.. cant remember the actual name of it. Supposed to be used for sticky valvetrain and stuck lifters. No luck... im just pullin the valve cover to see things, not rippin the intake out yet. My buddy came over with a stethoscope and we pin pointed it, drivers side, sounds like maybe lifter or stuck valve... taking valve cover off after i finish this cup of coffee.
Old 07-11-2009, 10:44 AM
96blackz28's Avatar
oh here is a vid, you can hear how loud that damn tick is.. check it out:
http://www.youtube.com/watch?v=npD9zpASZMA
Old 07-11-2009, 01:21 PM
Wooshie's Avatar
WOW that is loud. I'm not so sure its a lifter. Bent or misaligned pushrod is what it sounds like. You dont have to pull your intake to check those.
Old 07-11-2009, 01:33 PM
96blackz28's Avatar
yea i know it was loud.. turned out to be a loose rocker arm... it is completely silent now. Also realize part of my header gasket is missing on the drivers side.. how i dont know... but im gonna re do the header gasket and see if that helps it run better
Quick Reply: Oh hey... stuck lifter.. yay
