P0123 Code - Holley 58mm is the cause
Old 08-01-2009, 08:57 PM
ThreeHonks's Avatar
Default P0123 Code - Holley 58mm is the cause
I went WOT the other day and threw code P0123 for high TPS voltage. I have heard that this is because my Holley 58 mm will spin past 90*. Are there any cures for this? Do I have to make some type of throttle stop to stop pulling this code?
Old 08-02-2009, 07:28 PM
ThreeHonks's Avatar
anybody?
Old 08-02-2009, 07:36 PM
trippinholyman's Avatar
if it spins past 90 degrees then yeah, make a throttle stop. then it should stop throwing the code because it won't go out of the voltage range that is normal
Old 08-03-2009, 12:14 AM
buffman's Avatar
yeap time to make a throttle stop...
Old 08-03-2009, 01:31 PM
ThreeHonks's Avatar
Any ideas on how to make one?
Old 08-03-2009, 01:41 PM
WHITEBOY_ZACH's Avatar
Sorry to steal from you but what if its reading low TPS voltage??
Old 08-03-2009, 02:03 PM
ss.slp.ls1's Avatar
Many times with aftermarket TB's you have to slot the screw holes of your TPS and adjust it to read the right voltage at 0% throttle and WOT.
Old 08-03-2009, 06:00 PM
ThreeHonks's Avatar
Originally Posted by ss.slp.ls1
Many times with A TB's you have to slot the screw holes of your TPS and adjust it to read the right voltage at 0% throttle and WOT.
If I did that and moved the TPS sensor, wouldnt I then get a low voltage code? How do I measure what the correct voltage should be?
Old 08-03-2009, 06:03 PM
ThreeHonks's Avatar
Also what would happen if I just completely tuned P0123 off. Would this cause any problems?
Old 08-03-2009, 11:53 PM
buffman's Avatar
That may be the case, but with Holley TBs they can and will open more than 90%. Various ways to make a throttle stop. I'll have to see if I can get my friend to snap a picture of the one he made for his holley. Ideally you want 0% TPS to be around .59-.7 volts, and WOT to be less than 4.8volts.
Old 08-04-2009, 01:24 PM
ThreeHonks's Avatar
That may be the A, but with Holley TBs they can and will open more than 90%. Various ways to make a throttle stop. I'll have to see if I can get my friend to snap a picture of the one he made for his holley. Ideally you want 0% A to be around .59-.7 volts, and WOT to be less than 4.8volts.
Thank you very much! A pic would be awesome
Old 09-10-2013, 07:06 PM
Jimmy_d's Avatar
Could this cause the Trans to do some crazy shifting
Old 09-10-2013, 07:11 PM
buffman's Avatar
Untuned and you'll trash trans. Line pressure keys off TPS
Old 09-10-2013, 08:59 PM
Jimmy_d's Avatar
Ahh I figure it has smoked the 3 and 4 clutches .it randomly loses 3Rd and 4th
Quick Reply: P0123 Code - Holley 58mm is the cause
