cant read the pcm
Old 08-07-2009, 07:07 AM
ALEXZ28's Avatar
Default cant read the pcm
tried to get my car tuned last nite but when we tried to hook up the lap top wouldnt read, last month i tried to read the codes and still wouldnt read it so wasnt the tuner. and ideas????
Old 08-07-2009, 07:18 AM
the_merv's Avatar
LS1Tech 10 Year
Is your Cig. Lighter Fuse Blown?
Old 08-07-2009, 07:54 AM
Huff035's Avatar
have you ever got it to work on the car in the past?
Old 08-07-2009, 08:14 AM
KUTTER's Avatar
Welcome to the club alex. There is a slew of things it could be, being you just had the engine out and not no way to know if connection was working prior (when bought car). Ive been researching it. As mentioned check to see if your cig lighter is working you might get lucky. If not, commonly its a bad ground where someone spliced in etc.Backtrace all your wiring from where you put in your pillar guages.. Mine hasnt worked properly since rogers installed my reverse guages, so taking all my dash apart this weekend figure out where they fooked up.
Old 08-07-2009, 08:26 AM
ALEXZ28's Avatar
the pcm is working just not reading the plug, if the computer wasnt working the car wouldnt be running. cig liter works fine. its a obd1 with a obd2 plug. do the 95 camaros come this way?????????????????????????????
Old 08-07-2009, 08:32 AM
the_merv's Avatar
LS1Tech 10 Year
Yea they come that way. Take a Test Light and make sure #16 has power.
Could be a bad ground like mentioned, or and issue with the Serial Data Wire.
Old 08-07-2009, 08:57 AM
sepno77's Avatar
i believe if the radio is working the cig is working. it all gose off same fuse. i could be wrong tho.
Old 08-07-2009, 09:05 AM
Huff035's Avatar
I thought the horn was wired in with the cig lighter too. I remember in my 95 the cig lighter stopped working and so did the horn. replaced the fuse and it worked again. Radio still worked though...
Old 08-07-2009, 09:36 AM
KUTTER's Avatar
not on 96. My cig fuse was blown radio still works. Not sure about others.
Yeah alex pcm working not guarantee you port will work if there is a issue amongst all that wiring between point a and b. Without knowing history of car, best bet be to use test light and pull fuses one at time to see if you got a draw from any circuits.Go from there jonnys haynes has the wiring diagrams.Its a big can of worms, could be ground issue, short etc. From anything to aftermarket radio to alarm to the guages you put on depending on what you got power from.But didnt you have some pcm issues right after you put engine back in? That also be good place start.
Old 08-07-2009, 09:55 AM
H2O's's Avatar
Could be the cable itself. Especially if you are using the USB port on the laptop. This is a very common issue. The USB does not convert the signal correctly. Just a thought.
Old 08-07-2009, 10:28 AM
sepno77's Avatar
code reader isn't picking up his pcm either.
as far as the radio not working ya r right i was thinking about the horn. or maybe its just the way my radio is wired. **** idk.
Old 08-07-2009, 10:53 AM
KUTTER's Avatar
probably something you did, on one of your science experiments. "Making" things work way you want.i want my fans on all time! i dont wanna have use my cig lighter power my radar detector! lol damn electrical bully
Old 08-07-2009, 11:44 AM
ss.slp.ls1's Avatar
Default Scanning codes on a '95 F-body
FYI
http://shbox.com/1/xraycable.jpg
Old 08-07-2009, 11:49 AM
KUTTER's Avatar
if 16 pin not working why would it like that?
Old 08-07-2009, 11:56 AM
ss.slp.ls1's Avatar
Are you asking me?
The '95 is a OBD1 computer with an OBD2 ALDL port. You need to use a OBD1 code scanner to scan the codes stored on the PCM. The link I posted shows you how to do that.
Old 08-07-2009, 12:03 PM
sepno77's Avatar
Originally Posted by ss.slp.ls1
wow that sucks
Old 08-07-2009, 12:12 PM
KUTTER's Avatar
Are you asking me?
yeah i was sorry. Yeah i realize that, thats what threw me off.The scanner he used reads obd1 and obd2. Thought you were suggesting a non communicating 16 port could be solved via that method hense the confusion
good suggestion we should clarified the scanner that was used etc. There is just no communication coming from the aldl port.
Old 08-07-2009, 12:17 PM
ss.slp.ls1's Avatar
It doesn't matter if you have a scanner that reads both OBD1 and OBD2. You have to use the OBD1 connector (if it has both) and connect the pins like pictured in the link I posted. There is nothing that you can just plug right up and read the codes unless you modify a scanner to work.
Old 08-07-2009, 12:25 PM
KUTTER's Avatar
The scanner came with several cables.With the obd1 cable was able on it read sepnos 93 camaro no moding or pin jumping necessary. As well as a 96 camaro,99 vette, and a 05 300 all obd2.. All same process just diff cable
Or are you saying this problem is ONLY with the 95 being obd1 with a obd2 aldl?
Old 08-07-2009, 12:28 PM
ss.slp.ls1's Avatar
That cant be right man... The scanner came with several cables.With the obd1 cable was able on it read sepnos 93 camaro no moding or pin jumping necessary. As well as a 96 camaro,99 vette, and a 05 300 all obd2.. All same process just diff cable
For '95 cars only...
Quick Reply: cant read the pcm
