new opti still no start..
my 94 trans am broke down a couple months ago (again)... it started out on an interstate pull against a buddy, we take off and when i hit about 5 grand the car would act like you hit a rev limiter and fall on its face. it run about a month after that until it started doing it at 2 grand, then i parked it and no start since then.. i just replaced the opti and coil put it back together and still no start im lost and out of ideas. it will turn over but acts like it wont hit its getting spark. but no start. need help.. thanks..
anotheway to test the pump is to take it out, but not worth the effort if ur dropping the tank, just replace it. if pressure is that much down i assume its the pump,,,most probably
Similar issues here with mine about a year and a half-ago. My ground at the ICM wasn't that good and caused all kinds of problems. Check all your grounds for corrosion. If you have a side-mount battery, look for corrosion where your terminal screws go into the battery. I haven't messed with the fuel system yet so hopefully the guys above have provided you with some insight there.
