Head Porting - DIY
Head Porting - DIY
I have prepared my engine for the cam swap apart from pulling the hub and timing cover.
I had a look at the heads, and I could not believe how much metal I could shave off just by match porting them.
Now, since I have everything off, I can just take the heads off and match port them myself and a decent polish. I thought I might as well do so since I have everything off now.
Question I am asking is, how much will I gain from match porting with the CC503? Or could/should I have gone with a bigger cam? Are the gains going to be worth the extra cost of new headgaskets and ARP head bolts?
I'm not sure on the gains, waiting to find out for myself but it will be impossible to differentiate the gain from my cam swap. I would do it tho then you can get some thinner HG's and bump up your C/R as well. I prob wouldn't of done it actually if I didn't have a spare set of heads that were fully assembled(w/ the springs I needed), impala HG's laying around and a buddy who builds drag engines pushing me to port match them and show me exactly what to do.
If you don't go hog wild and just "clean up" the passage way and do mild bowl work you'll pickup a few hp. Now if you go nuts and increase your runner volume too much you'll decrease the air velocity and probably won't increase the flow #'s that much, hurting power.
If all I am going to do is remove them to polish the ports, then I won't bother. If I can get some worthwhile gains by match porting and polishing, then I will go ahead with it.
I need more opinions from people who have done the job before.
The engine runs great, and I was really happy with its performance.
I ordered http://www.summitracing.com/parts/PHP-66031/ for the headers and http://www.summitracing.com/parts/FEL-MS95580/ for the intake.
Location: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
1 Post
ive done one of my heads. waiting on my new polishing stones to come in. and just with all the carbon i cleaned out of the heads before even touching the actual steel made me happy lol.
If your portmatching you will also benifit from taking some metal out at the pushrod pinch. There is some material there that can be removed thats normally worth 8 or 10 CFM. Just know how thick it is and dont go overboard.
I just need to know if the gaskets I big enough for the match porting.
When I removed the intake, there were black patches around the ports and you can tell how much I can remove. The gaskets I removed were also Fel-Pro.
1 Post
i used polishing stones. they are pink stones (ill try and find the website, its saved in my fav on my laptop and im at work) and i use an air grinder the one where the bit sits ontop almost like a dremel. hell i suppose if you have the right bit you could use a dremel. ill post pics up this weekend or send them to you so you can see how i did mine. im pretty happy how they turned out...... DING lemme check my photobucket i might have some on there.
1 Post
oo damn i dont have any
lol sorry ill get some up this weekend. i didnt gasket match them i just knocked the carbon out and smoothed the edges out.
1 Post
http://www.eastwood.com/engine-porting-kit.html
heres and idea this kit will work but i use the carbide bits which are on that page ill post the link under this. i use the carbide bits to get all the edges cleaned up and what not but then i use pink stones which makes the surface smoother its more of a polishing stone instead of grinding.
heres the page the carbide bits are on the right
http://search.eastwood.com/search?p=...ing%20Kit&rk=3
1 Post
ok i feel like im stealing the thread. but heres a pretty decent write up on head porting i found on Hot Rod Mags. website hope all this helps
http://www.popularhotrodding.com/eng...ads/index.html
