Sudden, complete loss in oil pressure?!?!
What would cause this?
I was driving my SS down the road. I stopped at a stoplight and some chick was talking on the phone. My SS is cammed with open headers so its loud as ****...
We start driving and she yells at me because I was too loud so I stepped on it a little bit, not WOT, but slightly more than 1/2 throttle to annoy her more.
Immediately after I lose ALL oil pressure. It went straight to 0...do not pass go, do not collect $200.
No knocking, no pinging, nothing...It did not stutter, idle did not change, no unusual noises, no pops or anything when it lost pressure...
I shut it down for 2 days, and didnt touch it. When I restarted it today to pull it up on the curb to get under it and look around, oil pressure was perfect. WTF
It has an oil leak coming from behind the distributor. I thought it was the crank, but it is dripping onto the crank and getting slung around...The leak is no worse than it was before and I still have oil...
WTF?
WTF?
When you "lost" oil pressure, how was the car running? If it suddenly got rough running, then you actually lost oil pressure, as the lifters aren't pumped up anymore, the valve lash goes wacky, etc. etc....
IF, however, the car still was running reasonably well, then it's possible that you didn't actually lose oil pressure, but your o/p gauge or sending unit "hiccupped"......
well if you guys actually READ the original post I covered that lol...
I got under it and played with the OPS and it was on nice and tight, didnt seem anything was wrong with it.
lol yeah.
Well I took it for a drive to see what it did and it did it again. I gunned it and the pressure dropped...HOWEVER...when I stopped at a stop light I started to drive again and didnt hit the gas enough and I bogged it a slight bit on accident...When I did that, the oil pressure came right back.
Same as the first time...no knocks, no change in the way it ran, no difference in idle whatsoever. I think I may have a wire hitting a header or something and grounding out or the OPS is going bad.
If that was the case he would lose pressure while braking, not while accelerating. Since the oil would be forced towards the front of the pan when stopping. it doesnt sound like the pickup is the issue at all.
i bet he put the cam in backwards. i would tear down the engine and get it rebuilt
That is what I was thinking. It happened to me.
I wouldn't say that. When mine fell off, it didn't make much pressure at idle or slow engine speeds. I don't know what pressure it made when it was at WOT as I didn't look. Once I knew it spun a bearing, I beat the crap out of it Luckily the extended warranty took care of it
and i'm pretty sure my oil pickup is in the right spot because i was having the oil pressure issue BEFORE changing the oil pan gasket last summer and the pickup tube was in the proper place at that time. under normal driving and when my car is cold the oil pressure is fine but at idle warm it will read around 10psi or just about halfway between the red zone and 1/4 white mark.
this video is from last summer about 2500 miles ago right after i changed to 10w30. i recently went back to 5w30 because the place i went to get the oil changed at didn't have 10w30. i don't think it made much of a difference anyway
http://www.youtube.com/watch?v=Myfc5...e=channel_page
Seems to me like it'd be the wire is grounding/shorting out or there was debris that got sucked into the oil screen and blocked oil flow. Now in your post you say it goes to 0 but did it come back up at all for the rest of the drive home or did it stay at 0 the entire way home?
I would carefully go over the sending unit wire with a magnifying glass (figuratively speaking) and see if it's shorting out somewhere that would cause it to dip to 0. If not, if it truly went to 0 oil pressure, need to figure out what it was fast cause it won't take long for bearings to start going if there's no lubrication.
