Carbureted LT1 Runs on LS1 PCM
Today we tested the LS1 PCM as an ignition controller with a carbureted LT1 engine. We turned the key for the first time today; the engine started on the first crank. Throttle response is excellent. We're looking forward to the installation in a vehicle and 4L60E (or 4L80E) transmission control.
Video: Click to view 10MB video
Tuned with EFILive. 2002 Camaro LS1 calibration.
Crank and cam signal components.
So is the benefit of using the LSX PCM for ignition instead of a dist just the transmission control?
Consider what the LS1 PCM offers as an ignition controller that is not found in even the most popular ignition controllers...
- timing adjusted to coolant temp
- timing adjusted to intake air temp
- up to two knock sensor inputs
- 4L60E transmission control
- 4L80E transmission control
- two configurable VSS outputs
- high resolution crank signal (24x VS 4x flying magnets)
But it's not for every carb owner. These components pictured cost more than most ignition controllers. However, if you want a "modern" carbureted vehicle, the LS1 PCM is where it's at. For example, just an aftermarket 4L60E controller is $700 or more.
How much does that coil pack kit cost?
I am heading towards carb with a 383 and want to avoid an HEI. Can the LS1 PCM still control the transmission? Will I need an LS1 F-body specific transmission?
One of the biggest benefits of using the LSX PCM on a carb setup is to control an electronic transmission.
I've got my billet timing cover ordered and paid for, so as soon as that and my custom engine harness arrive from EFI I can install my new 383. Man I can't wait to drive the car with that engine and my S60 with 4.30's.
