LT1 knocking help. Video Inside!
Well guys, i have 127k miles on my bolt on lt1. Just drove it home from work last night (6 miles) and it started knocking when i started it. I noticed something wasn't right yesterday but it wasn't loud untill the drive home. Noise is coming from the passenger side valve cover for sure. My cousin thinks the valves need adjusted. He has worked on multiple 350 engines from being a star demo derby driver. I have no idea what it is, but it sounds like hell. He thinks we can remove the coil pack driver side and pull off that valve cover easily. Looks like we may be able to get off the pass side valve cover without removing the alternator?? Can i get a step by step on what to check? I printed out the adjusting valves and zero lash from here http://shbox.com/1/4th_gen_tech2.html#adjust_valves
What do you think the knock is and how much to fix this (if we can do it myself hopefully?) I know the front main gasket needs replaced because i have a small oil leak. Figure it's going to be in his shop for like 2 weekends anyway. I would really like to do heads/cam some day if i don't get rid of the car but i don't know how much more we would have to pull off to do so or how hard any of that is. Guess i'm just trying to get a starting point and advice/tips on what the knock is and how and how hard it is going to be to adjust the valves. Any info would be awesome! Here is a link to youtube of the engine at idle (cold engine, but doesn't go away when warm)
http://www.youtube.com/watch?v=fR3uQI6cYp8
I don't know about it being a rod knock it sounds like a bad lifter. Hearing how it stoped for a second and then came back, rods don't stop knocking. lifters will if the get stuck. Easyiest way to tell is take the time to pull the valve cover. Start the car with the valve cover off and see if you figure wich one is making the noise. You may be able to find it as soon as you pull the valve cover. If you verify its a lifter you can pull the intake and replace the lifters, and pushrods this weekend and be back on the road.
Wow thanks for the help so far guys, to answer the questions the knock does stop every now and then especialy as soon as the car is started, it wasn't the camera. So what i'm assuming i'll do is pull the valve covers. do i need to remove the alt. or anything else? and should i check the driver side while i'm at it? And i'm assuming if a lifter and or rod is bad i should go ahead and replace all of them? Decent brand name that won't kill my wallet? thanks so much and i hope i get some more replys!
Toasted.
I will bet rod and the crank could still be turned if it was only 6 miles and that short video run. If you run it much more add crank to the list. I will guess block is still ok but running it more could get a main.
Check valves first. I doubt it is lifter, but without hearing it in person could be a lifter or ro just seems rod is more likely.
Good luck
Good luck
easiest thing to do first is check the lifters and hope. if you dont see anything, try putting a heavier weight oil in the car and see if that stops the knock, if so its a rod.
That's a spun bearing, right where it always happens #2 cylinder. Your engine isn't shot. You will need a rebuild though. Do not run the engine anymore, take it to a machine shop.
