lt1 water pump question ( please answer ASAP)
Old 05-01-2010, 03:01 PM
Next level's Avatar
Default lt1 water pump question ( please answer ASAP)
ok guys im finally putting my motor in. I have a LT1 383 motor and im looking so dumb right now.
The heater hoses on the Water. if i block them am i asking for problems ?
The car never sees rain, snow or either clouds anyways. will it hurt anything or do they have to be put back in because of the reverse flow setup ?
Old 05-01-2010, 03:02 PM
1badzee's Avatar
You can cap off the heater core inlet/outlet on the water pump.
Old 05-01-2010, 03:03 PM
RamAir95TA's Avatar
You can block the heater hose fittings, sure.
Old 05-01-2010, 03:22 PM
SPEED#1's Avatar
Yes only block the heater hoses.
Old 05-01-2010, 03:26 PM
1badzee's Avatar
He can block everything but the lines coming from the radiator (upper and lower hose)
Old 05-01-2010, 03:43 PM
Next level's Avatar
thanks, just making sure
its been 3 years since this motor was in and i was going nuts think well if i do it what could happen lol.
let you guys know how everything works out.
Old 05-01-2010, 03:45 PM
Z28Roxy's Avatar
I hammered the heater pipes out of the water pump housing and had a machine shop plug the holes. Looks slick.
Old 05-01-2010, 09:45 PM
suicidal racing's Avatar
the driver side uses a 1/2inch freeze plug and the pass sides are 3/8ths..
Old 05-03-2010, 03:10 PM
Next level's Avatar
thanks guys. got the motor in just to connect some stuff and waiting for the injectors etc.
Old 09-16-2010, 07:47 AM
SickSixSpeed's Avatar
can you just loop them with a hose or is that a no no?
Old 09-16-2010, 08:32 AM
quik95lt1's Avatar
yea i did that wit mine as a temporary weekend fix when my hc started leaking.............no problem it just looks kinda gaff lol......i just pulled out the fittings and tapped them for a pipe plug......
Old 09-16-2010, 08:53 AM
Z28Roxy's Avatar
You can it just looks ghetto
Old 09-16-2010, 10:43 AM
93TAJ.C.'s Avatar
just put freeze plugs in, it looks clean and theyll never leak. thats what i did for the oil cooler line.
Quick Reply: lt1 water pump question ( please answer ASAP)
