Using Guides with Self Aligning Rockers?
Old 07-02-2010, 12:23 PM
C_Rules's Avatar
Default Using Guides with Self Aligning Rockers?
Whatsup everybody. My engine is apart and we noticed that my rocker arms are only screwing in 4 threads deep. My mechanic says using guides would help move things up so that the rocker would have more to grab on to. I believe my rockers are self aligning so if I add guides will that cause a problem? Also, is there a way I can tell for sure that the rockers are self aligning?
Old 07-02-2010, 12:56 PM
shbox's Avatar
You don't use guideplates with SA rockers. They could end up fighting each other for alignment control. What rockers do you have? SA rockers will have little tabs on the sides of the end that meets the valve tip.
Old 07-02-2010, 01:03 PM
MICHZ28's Avatar
Sounds like you need a longer stud. You shouldn't use sa rockers with guides.
Old 07-02-2010, 01:52 PM
RamAir95TA's Avatar
Hopefully you heard him wrong, because if you put anything between a bolt face (washer, guideplate, whatever), you REDUCE the number of threads into the material. Common sense.
Old 07-02-2010, 04:25 PM
JB_97ws6TA's Avatar
The OP is talking about putting guideplates on to increase the amount of threads that his rocker arm nut/poly lock will engage, which in this scenario is correct. Adding washers (not guideplates) to the bottom of the rocker stud wll raise the height of the stud in relation to the pushrod/valve spring increasing the number of threads available to engage in the polylock while reducing the number of threads engages into the head. Most rocker arm studs include washers to use in lieu of guideplates for self aligning applications.
Old 07-02-2010, 06:10 PM
C_Rules's Avatar
I have crane golds.
Old 07-02-2010, 06:11 PM
C_Rules's Avatar
Thanks for the advice. If it turns out i really do have self aligning rockers I'll most likely go that route.
Old 07-05-2010, 02:33 PM
C_Rules's Avatar
where can i get some washers to use on the studs? do we use any washers or some special ones made for this purpose?
should i go for longer studs instead? if so how much longer?
Old 07-06-2010, 03:28 AM
sbs
sbs's Avatar
http://www.summitracing.com/parts/ARP-200-8531/
http://www.summitracing.com/parts/ARP-200-8554/
Old 07-06-2010, 03:44 AM
xx_ED_xx's Avatar
maybe i am retarded but wouldnt getting some longer studs fix the issue correctly or trying to figure out the pushrod length to see if it is right?
Old 07-06-2010, 03:44 PM
C_Rules's Avatar
i guess both ways work. washers are just less expensive and will not really have a negative effect so i don't see why i wouldn't use them. the studs will still be deep enough into the head with the washers.
Old 07-13-2010, 07:21 PM
C_Rules's Avatar
if i use washers or buy longer studs would I also need longer pushrods?
Old 07-13-2010, 08:10 PM
ohio96ss's Avatar
Do it the right way with longer studs,you don't need longer pushrods.
Old 07-13-2010, 08:39 PM
Wicked94Z's Avatar
what studs, heads, valve length and pushrod length are you using?
Old 07-13-2010, 09:12 PM
C_Rules's Avatar
stock heads ported and polished a while ago. i believe the pushrods are stock length and the valve diameters are 2.02/1.60 but as far as lengths go i don't know. probably not much help lol. its ok my mechanic will measure everything. i was just looking to see if i could get an answer before i pass by later in the week.
Old 07-13-2010, 09:48 PM
draggin97s10's Avatar
wow.......
Quick Reply: Using Guides with Self Aligning Rockers?
