lt1 compression test results?
I was wondering what the stock compression should be on a lt1 iv looked and all iv found is that if its below 100psi you have a problem I figured with the 10.5-1 compression it would be over 200psi anyway my results were 160-170 on all of my cylinders for the dry test and around 175-180 for the wet test is this to low or is it alright?
