what plugs
Old 07-26-2010, 12:04 PM
TravisMcGill2000's Avatar
Default what plugs
What plugs do you guys think i should run. Im running a 12.1 355 with trickflow heads. I plan on spraying 150 to 200 shot. Im currently running autolite ar3935's.
Old 07-26-2010, 12:09 PM
Slowmaro95Z28's Avatar
I always used NGK TR55's. They are great for n/a motors but I think guys running spray are using TR66's. I'm sure someone else will correct me if I'm wrong.
Old 07-26-2010, 12:29 PM
Gojira94's Avatar
Non-projected tip plugs, heat range 6 minimum, probably 7, especially if you'll be spraying often. With that much compression, you'd probably need to go to a range 6-7 anyway, even without spray. Good rule of thumb I heard a while back is closing gaps .004 per 50 HP above stock. Ray at Nitrous Outlet (site sponsor) can get you dialed in. Shoot him a pm or give him a call.
Old 07-26-2010, 01:43 PM
09jyounger's Avatar
Try NGK TR66s, I've had good luck with them. As for gap, I agree with Gojira94. Ray would be the one to talk to about getting you zeroed in.
Old 07-26-2010, 02:44 PM
the tr5 6 7's wont work with the trickflow heads. they are .708 reach i need a .750
Old 07-26-2010, 03:17 PM
Wicked94Z's Avatar
r5671a-8
They did fine on the street for me, and that's running ethanol.
Old 07-26-2010, 04:48 PM
k thanks
Old 07-26-2010, 10:26 PM
Purple Poncho's Avatar
You also need a gasketed plug for those heads.
