LT1 newbie help me with this Demon possessed car
All right here we go.
I just bought a 95 LT1 383 stroker with a D1SC procharger ,
the car has been sitting dead for about 3 years .
I have swapped out the opti for a known good piece ,
I have spark at the coil,plugs and injector pulse.
fuel pressure starts at 42PSI , but drop fast as soon as the pump stops running ...down to 20 PSI in about 30 seconds or so,
I have a couple of ideals on this ..could the check valve in the pump be gummed up from 3 year old gas ??
can i disassemble it and clean it ??
it trys to hit ,,but im going to drain the tank and add some fresh premium and a couple cans of injecror cleaner ..anything im missing ??
thanks for your help..Dave.
The starting pressure seems fine. Once you get the engine going though I think the pressure should go higher rather than lower, to 43-49psi off the top of my head. Have you checked for a cracked/damaged injector?
no it hasnt even started yet ...but it does hit ..gonna drain the tank ,,and fill it up with some premium tommorrow ...I figure the gas is 3 years old ...i will keep you guys up to date as she progresses ...went from never having a 4th gen ...to buying 2 in less than 4 monthes ..lol..heres a couple of pics of both ..the blue car is the LT1..the orange car is getting a 555 BBC and a little sauce ...
ok little update ...was raining cats and dogs ..so i didnt drain the tank ...but I did get her to fire up and run ...idles a little rough ..but seems to rev OK ...gonna do a full tune up ..drain the tank change the oil and put the front back together ...thanks for the help and advice ...
Thanks for the compliments ...I kinda fell in love with it at first sight ...it has a 10 pt wolfe moly cage ..moser 9" and all BMR front and rear suspension...no the coffee cans are actually full of lead shot to simulate the weight of the complete .engine/trans /cooling system ...for setting the ride height while I build the headers ...theres about 450 lbs on the nose ..under the coffee cans there is a milk crate with weights in it ...I started a build thread ....but progress has been a little slow ...too many projects ..lol
