best spark plug?
Old 07-31-2010, 01:10 AM
ryanosborne's Avatar
Default best spark plug?
whats the best plug you recommend for my lt1? and what gap to run?
Old 07-31-2010, 01:34 AM
robsquikz28's Avatar
stock lt1 tr55 at .055"
Old 07-31-2010, 01:58 AM
Spiers's Avatar
Dont you think it would depend on the motor combination...
Old 07-31-2010, 07:51 AM
RamAir95TA's Avatar
Stock gap is .050", not .055".
Plug choice depends on the motor. TR55s and TR55IX are very popular for stock and mild N/A motors.
Old 07-31-2010, 10:08 AM
mrchyzy16's Avatar
Whatever you do, dont buy bosch plugs. I have had nothing but problems with those.
Old 07-31-2010, 10:36 AM
97lt1stangstomper's Avatar
i run ac delco platiums run good
Old 07-31-2010, 10:39 AM
killagt's Avatar
NGK for everything, even for my lawnmaw ( spell hehe ).
well im goin to be running them with that a1 cam kit, im just trying figure out everytihng i need
Old 07-31-2010, 01:01 PM
RamAir95TA's Avatar
Go with the NGK TR55s gapped at .050".
Old 07-31-2010, 01:07 PM
JimKellyfan's Avatar
It depends on what you're plugs coming out look like. You may need to go to a hotter or colder plug, but I would start with putting OE AC Delco's in, then pull them after 30 days and see what they look like and adjust if necessary.
Old 07-31-2010, 01:19 PM
RamAir95TA's Avatar
How would you know based on high mileage plugs to go to a hotter or colder plug on a completely new, rebuilt motor with different characteristics that OEM?
Old 07-31-2010, 01:21 PM
great421's Avatar
My current setup = NGK TR6IX gapped at 0.037" - but I'm boosted.
When N/A, I was running TR55IX gapped at 0.052"
Old 07-31-2010, 01:36 PM
Go with stock to start.
Then, run them for awhile.
Then, depending what they look like coming out will tell you what direction is needed to go in, if any.
( running lean, carbon foul - tan, white, black, yada, yada etc. )
Old 07-31-2010, 01:39 PM
Ok, a1 cam kit.
Is that a longer or shorter duration than oe ?
I hadn't seen that post.
What other mods from oe are in place ?
