Cammed Guys Lets see your timing tables
1 Post
Just want to get an idea of what you cammed/headed Guys are running for timing. Trying to get this thing tuned! I got the AFR just right now I need to get the timing tables right. My mods are stock shortblock, LE1 heads, .026 head gaskets, 11.4/1 compression, 226/230 .565/.565 111 lsa. Here is my timing tables. I'm getting a knock retard When I first put the pedal to the Floor.
where did you get those tables from?? i'm on my phone at work right now, i'll get back to you tomorrowish with a longer reply... what kinda advance are you running at idle? IIRC you're at like 20,000 ,000ft elevation but i still dont see a point for so much advance in alot of areas in those tables.
I think stock maxes out at 46 in those low map mid rpm areas, I would also like to see some timing tables to compare with mine. I tuned my VE and MAF and the WOT stuff but I haven't touched my timing tables because there is no knock anywehere in it right now and my datalogger mysteriously stopped logging knock and IAC counts.
1 Post
Yup these are from a solomon tune. Spent the $70 bucks with Him and the car runs pretty good except for some knock retard when you first nail the gas. I logged the car all last week and He tweaked it 3 times. Its getting better I just want the knock retard to go away. And yes I'm @ 6,000 ft elevation and only have 91 octane available as the highest grade pump gas.
