ABS Inop
Old 08-04-2010, 10:05 PM
pillarpod's Avatar
Default ABS Inop
My light came on awhile back. I checked all fuses and replaced the relay. Didn't fix it. Check the Ohms on the ABS senors and all were in correct range. Brought it to GM for them to check it out. Codes thrown were
CO1216
C1295
they said it could be one of the three problem.
1. Bad relay
2.Brake switch
3.EBCM which is like $455.
already replaced the relay, if it was a bad brake switch would my brake lights still work?
is there any other options?
Old 08-04-2010, 11:57 PM
1redta's Avatar
check the 3rd brake light bulbs
Old 08-05-2010, 10:20 PM
pillarpod's Avatar
my brake lights are fine, i'm asking if the brake switch was bad, would they still work cuz they do and my ABS doesn't work. No point in replacing something that doesn't need to be replaced
Old 08-06-2010, 08:31 AM
quik95lt1's Avatar
idk if you have headers on the car but check the wires to the front sensors.......mine are realllyyyyy close to the headers and i burnt one up.....when that happens the light comes on........id check that out first may be and easy cheap fix....
Old 08-06-2010, 11:20 AM
1SWT95Z's Avatar
do you have a stock spoiler or an SS spoiler with the LED brake light?
Old 08-07-2010, 12:23 PM
pillarpod's Avatar
SS spoiler with LED light
Old 08-07-2010, 12:41 PM
Adam1203's Avatar
thats your problem i think. did the light come on when you put the ss spoiler in? i read some where that an extra relay has to be installed with the ss led lights.
[url]https://ls1tech.com/forums/lt1-lt4-modifications/1202577-abs-inop-after-led-3rd-brake-light.html[/urlb]
here is a link to shboxes were it shows you how to do it http://shbox.com/1/relay_for_ss_spoiler.jpg
Old 08-07-2010, 02:16 PM
pillarpod's Avatar
thanks, i'll try her out
Old 08-07-2010, 04:33 PM
1SWT95Z's Avatar
i just fixed this problem with my 95 Z and my ss spoiler. bascially the led does not give resistance like the stock bulbs do so you have to wire in a resistor to fix it. there is a post with a wiring diagram on how to fix this. it is about a week old in the lt1 section. search for it and you should see the 2nd or 3rd post with the link. i think it is titled "just changed to ss spoiler now abs light is on"
Old 08-07-2010, 06:14 PM
pillarpod's Avatar
i got it put on and that is what it was, thanks!
Old 08-07-2010, 06:24 PM
1SWT95Z's Avatar
glad to help. i waited like 6 years to finally get an answer on here on how to fix it.
Old 03-30-2013, 07:20 AM
mcalus's Avatar
This is an old thread but I figured I'd utilize it.
How do I know what relay to use? Will any relay work?
Old 03-30-2013, 08:15 AM
Village Troll
SS RRR's Avatar
You need to find out whether or not a normally open or closed relay is used. Shoebox may have diagrams to answer at least that question.
Old 03-30-2013, 08:18 AM
mcalus's Avatar
Not a relay expert
Old 03-30-2013, 08:36 AM
Village Troll
SS RRR's Avatar
Neither am I. Any 12v auto relay will work. If that relay is not charged in that diagram it looks to be a normally open relay.
Quick Reply: ABS Inop
