Brakes suck. Its the camshaft robbing vacuum.
Old 08-09-2010, 04:51 PM
wrd1972's Avatar
Default Brakes suck. Its the camshaft robbing vacuum.
Been chasing a hard braking condition under panic stop conditions. All braking components have been determined to be good including the master and booster. I have to stand on it to make the ABS kick in under panic stop.
FTR I have 12" LS1 brakes too.
For giggles I put a vacuum guage on the intake and I have:
12" at idle with AC off
10" at idle with AC on
Stock cam made 20"-22" IIRC.
I am confident I dont have any vaccum leaks. Motor runs well and BLMs are near perfect. So its the cam robbing my vaccum that is affecting my braking. I have a 224/230 which aint that big. But its on a 107 LSA with lots of overlap and according to folks who are smarter than I am, thats what is doing it.
What are my options here other than replace the cam with a tamer LSA??
Old 08-09-2010, 05:58 PM
RamAir95TA's Avatar
Use a vacuum canister if it bothers you that badly. Honestly, I can't see it being that big of a deal especially if it's under panic-stop conditions only.
Old 08-09-2010, 05:59 PM
FlamingChicken's Avatar
i dont know from experience but maybe try a vacuum reservoir. think thats what they are called.
edit: or maybe its a canister lol either way beat me to it.
Old 08-09-2010, 06:41 PM
LSWHO's Avatar
Correct me if I'm wrong... but isn't that THE MOST IMPORTANT TIME FOR YOUR BRAKES TO WORK CORRECTLY?!?!?!?!!
Old 08-09-2010, 08:05 PM
96capricemgr's Avatar
What is the idle set at? A vacuum reservoir is a good idea but a slightly bumped up idle might do the trick too.
Old 08-09-2010, 08:33 PM
Wicked94Z's Avatar
i guess you'll have to grow a set of leg muscles, put a different cam in, or I have an electric vacuum pump from ssbc I'll sell you. How much timing are you running at idle and what's your idle rpm? You're not running alot of overlap...
Old 08-10-2010, 12:13 AM
wrd1972's Avatar
I had a vacuum canister installed and saw little to no improvement in braking. I sold it for a profit considering I got it for free. Again I am not convinced it did any good.
Idle is 950 but I dont expect to see a big improvement by increasing it. I am going to bump it up a bit just to see what happens for giggles. Seems like vacuum bump is the best cheapest fix.
Idle timing is around 25-28 or so. How much for the pump? I cant really speak to the overlap other than to say my vacuum is ****.
Please PM me.
Old 08-10-2010, 12:25 AM
speed_demon24's Avatar
I only have 10" of vacuum at idle and I have no problem at all kicking on the abs. My pedal is stiffer than other cars I drive but nowhere near stiff enough to make it difficult to get the abs to kick on. My $$ would be on cheap or glazed pads.
Old 08-10-2010, 12:32 AM
fleetmgr's Avatar
The idea of a vacuum canister is to give you multiple brake pedal hits, not to give you any more braking power. In a panic stop, where all you do is stand on the brakes, if you lack braking power then you need different brakes and not more vacuum.
Old 08-10-2010, 12:37 AM
wrd1972's Avatar
Good point.
I have ceramic Raybestos pads that might not be doing a good job. I am pondering getting some Hawk HPS pads to help improve braking.
Old 08-10-2010, 12:48 AM
Originally Posted by wrd1972
Good point.
The only thing ceramic pads are good for is keeping down brake dust. I have no idea if those pads are bad enough to cause the braking problem you have, but some hawk hps pads will defiantly be a big improvement over them.
Old 08-10-2010, 12:53 AM
wrd1972's Avatar
What pads do you run?
Old 08-10-2010, 12:55 AM
HPS for the street.
Old 08-10-2010, 12:56 AM
RamAir95TA's Avatar
Hawk HPS pads = rock solid. I've been running them for awhile. Not the best as far as dust is concerned, but they show definite improvement over ceramics.
Old 08-10-2010, 01:25 AM
robsquikz28's Avatar
raybestos ceramic pads willl not give you that problem at all. My buddy Speed has them on his wifes car with ls1 brakes and those brakes are hard as a rock. Even the cam is similar to what you have. You might have something else goin on. How much pad life is left on all pads. If they are really low or your rotors are almost done then you will have a very crappy pedal. It will take more effort to push the pedal down for them to engage.
Old 08-10-2010, 01:54 AM
idformula's Avatar
I have EBC green stuff pads and they are great.
Old 08-10-2010, 02:14 AM
Worn pads would require the exact same amount of pedal travel to engage the brakes as brakes with new pads would.
Old 08-10-2010, 06:26 AM
wrd1972's Avatar
To clarify. They are Napa Safety Stop ceramic pads made by Raybestos. They are the cheaper grade of ceramic pads too. I would guess there is easily 80% plus pad material remaining. I will most likely put some HPS pads on prior to considering the vacuum pump.
The booster is good. The MC is replaced and it made no improvement. Calipers are rather new considering I rebuilt them. ABS module is fine considering I parked the pistons at the top and pulled the fuse which essentially bypasses the ABS functions. Lines are well bled too so I really dont think there is any mechanical issue with the brakes. The disks look a bit blue so that might indicate a problem with the pads as well.
The brakes work better when the car is decelerating (clutch out) and vaccum is at its greatest. Its worse decelerating (clutch in) and vaccum is essentially the same as at idle. So obviously vaccum is playing a generous role here.
Old 08-10-2010, 08:30 AM
ElkySS's Avatar
my brakes suck too. but i have stock lt1 brakes. was thinking about braided lines. maybe that would help?
Old 08-10-2010, 08:49 AM
Badazz 97 TA's Avatar
no, there not gonna make any difference. LS1 brake swap!
Quick Reply: Brakes suck. Its the camshaft robbing vacuum.
