PCM not reading? how can i fix this?
Old 08-11-2010, 06:27 PM
LT1559's Avatar
Default PCM not reading? how can i fix this?
Since i've bought the car I wasn't able to scan it with a scanner and took it to 3 shops and they said that they weren't able to scan it either even with their high-end scanners. The last mechanic said that I needed to get it reflashed. Each scanner says that it cannot communicate with the engine control unit. Anybody else have this problem? I also asked him how my car was able to run if the pcm wasn't working, and he told me that some models are able to run if the pcm isn't working so idk...from what i know the pcm controls all of the electrical components.
Old 08-11-2010, 06:42 PM
shbox's Avatar
Perhaps all of them did not know that despite the car having a 16 pin DLC, it is not OBD-II. I bet they were all trying to use an OBD-II scanner instead of I.
Old 08-12-2010, 04:16 PM
kmracer's Avatar
if its obd2, check the cigarette lighter fuse.
Old 08-12-2010, 04:58 PM
shbox's Avatar
95s are not OBD-II, though if the scanners they were all trying to use required the 12v from the DLC, then checking the cig lighter fuse would be wise.
Old 08-12-2010, 06:18 PM
LT1559's Avatar
lol okay, i will run down to the shop to try and get it scanned again today, this time making sure it's an obd-I scanner
Old 08-12-2010, 06:22 PM
94impguy's Avatar
I got lucky when I got my scantool, it has two OBD2 cables. One that is OBD2, the other that is actually for the 95 GM's with the half and half..
Why it requires it's own cable too is odd, unless the pins are in different spots?
Old 08-12-2010, 06:39 PM
LT1559's Avatar
hmm, what do you mean by half and half?
Old 08-12-2010, 06:41 PM
Nomind's Avatar
It's a ODB-II connection, but the computer is ODB-I. It requires a scanner and cable for that set of circumstances.
Old 08-12-2010, 06:57 PM
94impguy's Avatar
Yea, that funky OBDII shell with OBDI data. I call it GM's half-and-half..
Old 08-12-2010, 07:08 PM
MasterTomos's Avatar
the reason your pcm is not reading is like shbox said more than likely.
'95s where OBD1 with an OBD2 connector. They probably looked at the "OBD2 connector" and figured it was an OBD2, used the OBD2 scanner, and got nothing. I've had a shop do this to my car before...
go back and tell them it's OBD1
Old 08-12-2010, 07:49 PM
shbox's Avatar
If a 12 pin OBD-I cable is all you have, you can adapt it like this to read codes:
Quick Reply: PCM not reading? how can i fix this?
