!!Filler Tube!!
!!Filler Tube!!
The piece that the oil fill cap attaches to is constantly loose and is leaking some oil. i try to tighten it and its barely stays on. Almost like only 1 thread is catching. Anyway. 2 questions. 1. can i run just the cap on the valve without an issue 2. where can i buy a new filler tube. i cant find it anywhere.
do you know his profile name on the forum?
anyone else know where i can get a replacement, possibly just oem
i just took the car out for a 15 min run. came back and no leaks at all with just the cap on. icould also be crazy but once the car hit running temp the oil pressure looked a bit higher than usual. maybe because that cap was loose and leaked?
