Who runs LE hardware on here?
My car's still under construction but I have LE3 heads/ported intake/847 cam/LT headers & true duals. I don't have any rwhp/rwtq numbers or track times yet obviously but I'm looking for high 11's low 12's on motor.
I run LE's stuff. I've ran 7.30's in the 1/8th with mid 1.6 60's and horrible weather. I plan on running 11.1-11.2 on motor this fall in 1200-1700DA (basically good weather around here)
I used to compare my car to Joe's AI car. But after realizing He's been able to run in negative DA, and has weight advandages over me, theres no comparrison at the moment.
My car:
383 12.3:1
LE2 heads
3600 Race weight
Full accessories with Air conditioning
Full leather interior.
100% stock suspension
hooker catback with no cutout
Corrected DA my car says it will run 11.20@121MPH. If thats true Joe's car is still faster. But with some suspension and if I WERE to do any weight reduction I do think I could get there.
My car in no doubt is a full blown street car. No linelock nothing. I did invest in an aftermarket torque arm, and a transmission crossmember to relocate it. With this suspension im hopeing to go faster. Time will tell.
My car:
383 12.3:1
LE2 heads
3600 Race weight
This is my second LE set up LE1 went 12.50's
My new LE2 set up 11.70 116.2
Full weight street car Just started playing with suspension I don't think high 11.50 low 11.60 out of reach!
For the past 2.5 years I've been running LE2 Heads (561 castings unfortunately) and a Bret Bauer 224 intake duration cam which is who did the cams for LE back then. It has been my favorite purchase to date for the car and has been exceptionally reliable. This summer I took it on a 6 hour roadtrip and then an 8 hour roadtrip over my gas efficient DD because I enjoy driving it so much.
My best pass so far has been an 11.47 at 119mph with a 1.5x 60' in the summer heat and my raceweight that day was 3360#. Car is an auto and has a stock bottom end FWIW.
LE2's ported intake, custom grind cam, runs like a beast! first time out with a tight nitrous converter running on the motor she pulled an 11.86 @ 117. much better times coming soon!
403rwhp 387lbs SAE through LE1, 306 cam, m6, and a 9" rear end. Went 11.6s. Know I could have hit 11.5s and possibly 11.4s but I sucked at shifting which is why I have switched to an auto.
