Clutch Recommendations
Clutch is going and need to put a new one in this winter. My car just has bolt-ons, maybe step up to a somewhat mild cam setup this winter since I'm dropping the motor for some maintenance. What would you recommend?
search the forum for competition clutches. They make a good clutch for the money. I paid $299 for a stage 2.
www.competitionclutch.com
Edit: try this thread:
https://ls1tech.com/forums/lt1-lt4-m...-its-here.html
Which clutch on the site would you recommend for someone that doesn't daily driver and doesn't use it on the strip? I just drive it on the street to have one. I do not plan to have over 400 horsepower anytime soon.
I have gave this clutch hell and it's still running great. This will be the only clutch I will ever buy again.
http://www.competitionclutch.com/sto...hp?vinvid=6858
it's rated to 550hp, so you should be a-ok with it.
for the $299 the 4134-2250 "looks" to be a solid set up. It would compare to a stock valeo PP with the McLeod DF disc....you pay $410 if you buy a auto part store clutch for $230 and $180 for the McLeod disc.
Recieved my clutch kit from CCI. here's some photos...
flywheel side:
PP side:
alignment tool and new pilot bushing:
PP, looks like a valeo unit, with new T/O Bearing installed:
and the free t-shirt:
I'll post up more after it's installed and got some miles on it.
flywheel side:
PP side:
