Parking Brake adjustment on 94 z
Old 09-27-2010, 10:26 PM
sheikss's Avatar
Default Parking Brake adjustment on 94 z
Got a buddy who has a 94 z28 and the parking brake needs adjusting. I know how to do it on the ls1 cars but have no clue on the lt1 cars. I know the adjustment is on the caliper just not for sure where. Right now I can pull the lever all the way back and push the car.
Old 09-27-2010, 11:42 PM
tricked94camaro's Avatar
who cares about parking brakes? parking brakes are for ricers who cant do a real powerslide like a camaro.
Old 09-28-2010, 12:22 AM
suicidal racing's Avatar
^ state inspections do
Old 09-28-2010, 07:49 AM
wrd1972's Avatar
That is a retarded statement and not helpful to the OP or the discussion at hand.
There is a tiny set screw that adjusts the "grab plate" on each rear caliper. The grab plate is a plate with a hole in it and when the e-brake handle is pulled, the grab plate grabs the pusher shaft behind the inner pad to apply pressure. When the normal pedal brake is used, the pusher shaft behind the pad slides within the grab plate. The adjustment is very sensitive so you will have to play with it to get it right.
What makes things worse is the shaft and the grab plate will wear and therfore require adjustments from time to time. Also the set screw is very small and like to get frozen so be careful breaking it loose. Might want to put some anti-sieze on it.
The parking brake design for LT1 brakes is total ****. Thats one reason I went to LS1 brakes.
Old 09-28-2010, 03:48 PM
sheikss's Avatar
Thank you sir.
Old 09-29-2010, 02:49 AM
the_merv's Avatar
Parking Brakes are for those of us with T56 cars and have to use them to park at running idle.
If you didnt drive an Autofaggot you would've figured that out.
The following users liked this post:
Chris Iglehart (08-27-2020)
Old 09-29-2010, 09:34 AM
Village Troll
SS RRR's Avatar
You've been on quiet time for a long while. Haven't heard a peep out of you regarding this type of tone. You back now? Ready to shake up the f-body world?
Old 09-29-2010, 09:52 AM
SS MPSTR's Avatar
Old 09-29-2010, 09:55 AM
SS MPSTR's Avatar
Logical initial response, then dropped to the stupidity of the comment you responded to...
Old 09-29-2010, 03:47 PM
the_merv's Avatar
The last part was a little friendly sarcasm..poking a little fun..
Here's a legit one for ya..
**** off.
Na not quiet time..just been busy..been here all along.
You still as slow as you've been?
I have the diagrams for this set screw..if you need them let me know. PM me an email and I'll send them to ya..
Old 09-29-2010, 05:59 PM
speed_demon24's Avatar
**** off.
Feel free to post up the timeslips from your 4xx cubic inch lsx.
Old 09-29-2010, 06:10 PM
chavez885's Avatar
Send those to me merv.....I screwed up my parking brake and should probably fix it.
knifefish (10-02-2020)
Old 09-29-2010, 06:39 PM
BlueRamAir's Avatar
I need them also. My e-brake hasn't worked in a year.
Old 09-29-2010, 06:58 PM
Village Troll
SS RRR's Avatar
As slow as the day is long. No, you've pretty much been on quiet time. New sig and from the looks of your posting mannerisms, your mouth is back. Low 10's, right? Isn't that what you've promised to run with this setup?
Old 09-30-2010, 01:55 AM
the_merv's Avatar
Damn, it took you 24 hours to make a 1/4 mile pass?
Ummm..negative.
New sig
New car..
..and from the looks of your posting mannerisms, your mouth is back.
More like my fingers..you arent lucky enough to get my phone number to hear my mouth.
Got a cute sister..I'll give her my number..
I got ya all day long homie..
Will do when I get them..I dont have any for this car.
Tuned 408, T56, 3.90 Gears, running like a Min Pin on crack!!
Email sent..for the rest pm me and e-mail address and I can send you the diagrams from the Manual for this.
Old 09-30-2010, 02:03 AM
What did the old car run? I must have missed the thread.
Old 09-30-2010, 02:09 AM
the_merv's Avatar
Old car is gone man..Silver one is here and fast, that's all that matters.
You guys pm me your emails for them diagrams..
Old 09-30-2010, 06:55 AM
Village Troll
SS RRR's Avatar
Deep 10's fast, right?
Old 09-30-2010, 07:42 AM
*02WS6TURK*'s Avatar
Lmao...this is some good reading. Merv FTW.
Old 09-30-2010, 11:01 AM
3rdgen92maro's Avatar
[QUOTE=the_merv;13930580]Old car is gone man..Silver one is here and fast, that's all that matters.
The silver one is just as big of a turd as the red one Merv...im sure its gotta be a mid 10 sec car by now...making 550 unproven rwhp.
Quick Reply: Parking Brake adjustment on 94 z
