switching to 98-02 brakes
Old 10-03-2010, 11:03 AM
Tolley's94z28's Avatar
Default switching to 98-02 brakes
what would i need to switch to 98-02 brake calipers?
Old 10-03-2010, 11:17 AM
kornboy's Avatar
For the fronts,ls1 spindles,rotors and cailpers all from a ls1 car.
For the rear,ls1 backingplates,rotors and cailpers.
Just unbolt brake line from the back of the cailper. don't miss with the hardlines. Thats about it!
Old 10-03-2010, 12:25 PM
the_merv's Avatar
Any 98-02 F-body will have them Brakes..V6 or V8 it doesn't matter.
Old 10-03-2010, 01:24 PM
sweet, so my parts car has all i need then!
Old 10-03-2010, 01:35 PM
96lt1m6's Avatar
Front:
Remove ball joints,tie rod ends brake line from body and the abs wiring remove entire assembly from donor car
Rear:
E-brake cables,brake line from car to housing,housing to calipers....Open rear cover disassemble rear,pull axles and remove backing plates,calipers and rotors. dont forget the e-brake cable brackets...
Old 10-03-2010, 02:08 PM
NewOrleansLT1's Avatar
Originally Posted by 96lt1m6
Rear:
Damn! I wanted to do the rear brake swap, but screw it if I have to remove the axles out of the rear...
Old 10-03-2010, 02:18 PM
kinglt-1's Avatar
removing the axels is not that big of a deal...
Old 10-03-2010, 03:28 PM
Valkyn's Avatar
Remember that some LS1 guys switch to LT1 brakes in the rear so its easier to clear drag rims.
So if you plan on running them in the future you might wanna stay with your stock brakes in the rear.
Old 10-03-2010, 04:10 PM
96lt1m6's Avatar
That is useless now since a few 15" wheels now fit but i know your point.
OP, you can always swap the entire rear end it is about 10 minutes quicker.
Old 10-03-2010, 05:29 PM
the_merv's Avatar
That's why I kept my LT1 Brakes bolted to my Moser..
Old 10-03-2010, 05:42 PM
i have 18's on the back so it shouldnt be a problem
Old 10-03-2010, 10:44 PM
Travis Johnson's Avatar
I don't think the rears are really enough of an improvement to justify a switch.
Old 10-04-2010, 01:05 AM
94LT1Bird's Avatar
just swap a rear out of a ls1 car...alot faster...i picked mine up for $100
Old 10-04-2010, 05:14 PM
Rob94hawk's Avatar
Need to remember this thread
Old 10-04-2010, 06:48 PM
joelster's Avatar
There is almost no benefit to going to an LS1 rear brake. The front brakes are slightly better and the calipers are lighter so it's a cheap way to improve braking and shed a little weight, but for the rears it's useless.
Old 10-05-2010, 03:56 PM
Rob94hawk's Avatar
Front:
Where's everyone getting their parts from? Junkyard?
Old 10-05-2010, 04:17 PM
there is justification when i have the brakes sitting in my garage and my lt1 brakes keep f**king up for some reason lol
Quick Reply: switching to 98-02 brakes
