Did you guy note our oil filter, do not have ADBV ?
Old 10-03-2010, 03:52 PM
killagt's Avatar
Default Did you guy note our oil filter, do not have ADBV ?
Some one just point it out for me today, that oil filter for lt1 do not have anti drain back valve on it. event with mobil 1, wix, pure1, k&N filter. Mabe because of the way it mount ? so it dont need ADBV ? I stay away from purelator or carquest, napa select. because they dont have ADBV, since those high dollar dont even have ADBV, i might stick with purelator classic for $3.15. Rather then 6-11 dollar I pay for wix or K&N.
Old 10-03-2010, 06:09 PM
leadfoot4's Avatar
Look at it this way....the filter on an LT1, or any small block Chevy V-8, is mounted in the VERTICAL position, with the inlet/outlet located on the TOP of the filter.
HOW would the oil drain back to someplace? Think I'm kidding? When you change your oil, and spin the filter off, do you get a little oil spewing on your arm? Also, is the filter full of oil?
Old 10-03-2010, 06:32 PM
robsquikz28's Avatar
k&n or acdelco 454 if you need the clearance.
Old 10-03-2010, 07:09 PM
fex77k's Avatar
Well you have the the high pressure bypass in the oil filter plate, that will let some unfiltered oil past. I wouldn't really worry about the filter cause its in the vertical position.
Old 10-03-2010, 08:37 PM
killagt's Avatar
should I stick with puralator classic, like I say I bought those high dollar filter its because i though it have adbv on it, and since it doesnt, i can pretty much run any oil filter i want then, accept fram ( Fram XG is good ).
Old 10-03-2010, 10:21 PM
chevymec's Avatar
I just run the AC Delco PF 1218. Its a little bit shorter than it use to be but it still holds more oil than the PF 454.
brucer's Avatar
stp and napa golds are good cant go wrong with delco's either...
the regular sized wix 51060 filters were only $5 at partspro.
Old 10-04-2010, 06:06 AM
leadfoot4's Avatar
Baldwin B6 for me....
Old 10-04-2010, 06:20 AM
Village Troll
SS RRR's Avatar
It is a non-issue. The oiling system does not drain once the engine is off. If there is concern, get some Slick-50.
Old 10-04-2010, 09:41 AM
killagt's Avatar
:S TFU:
Old 10-04-2010, 10:12 AM
quik95lt1's Avatar
yea thers no valve and you dont need one oil's not going to defiy gravity and climb out of the filter lol.....you're good to go........i run a 3 dollar Fram on my 8000rpm NA motor lol
Old 10-04-2010, 10:44 AM
speed_demon24's Avatar
Oh boy.
Old 10-04-2010, 10:50 AM
quik95lt1's Avatar
Originally Posted by speed_demon24
Oh boy.
oh boy what? lol
Old 10-04-2010, 10:54 AM
oh boy what? lol
Look at some cutaway pics of fram oil filters and you will never run one again. Cardboard endcaps + the least amount of filter media in the filters.
Old 10-04-2010, 11:15 AM
sweetbmxrider's Avatar
nothing wrong with purolater, been using many of them for years.
Old 10-04-2010, 04:54 PM
killagt's Avatar
man u should not use fram regular filter at all, their fram xg is best.
Old 10-04-2010, 05:29 PM
Young Maro's Avatar
I'm glad I found this post, because after installing my headers the normal length oil filter looks like it's going to be a PITA to change now.
So the one to run is the PF 1218 or the PF 454?
Old 10-04-2010, 05:45 PM
Young Maro's Avatar
Wow, RockAuto has a wholesaler closeout on the PF454's. They are only like $2.50, but the shipping is like 8 bucks. Makes me want to buy like 20 of them
Old 10-04-2010, 06:27 PM
leadfoot4's Avatar
I agree!!
Check out "bobistheoilguy.com"
That's why I run Baldwins.....
Old 10-04-2010, 07:54 PM
AChotrod's Avatar
K&N has a nut to remove it. Well worth the extra change IMO.
Quick Reply: Did you guy note our oil filter, do not have ADBV ?
