Tips on how to clean up cylinder heads?
Old 10-07-2010, 09:42 PM
whytryz28's Avatar
Default Tips on how to clean up cylinder heads?
Got my heads disassembled and pressure washed them pretty good to get the thick grim off. Now how do I go about cleaning the bottom surface? I used a wire wheel (pic of similar below) to get some of the carbon off, didnt want to get too much into (didnt get into the chambers yet). Was wondering If i could use it on the head or switch to something else?
Used to working with Iron heads, so Aluminum are a different ball game for me.
Pic of head (drive I think)
Edit: Sorry for the big pic, still dont know how to work my iphone lol
Same thing
Old 10-07-2010, 10:08 PM
RamAir95TA's Avatar
Do NOT use a steel wheel on an aluminum head. Very bad idea.
I have found that Hi-Solv is amazing at cleaning heads. Brake cleaner will also work.
Old 10-07-2010, 10:34 PM
SoxXpupPeT's Avatar
that wire wheel might damage the aluminum... dont use to harsh of a chemical because it can eat away the aluminum.... strip them and sand blast them
Old 10-07-2010, 10:41 PM
robsquikz28's Avatar
clean them up real good and use a plastic razor blade, brakekleen and lots of time and effort to get that head real clean
Old 10-07-2010, 10:50 PM
whytryz28's Avatar
Yeah was a bit iffy on the wire wheel. I have some Purple Power, would that be ok to use? Also some scoth brite pads?
Old 10-07-2010, 10:55 PM
1badzee's Avatar
I used brake parts cleaner and scotch brite pads. Cleaned them up VERY well
Old 10-08-2010, 05:59 AM
SpeedDensityZ's Avatar
Brake cleaner and something to scrape the gasket surface. Elbow grease.
Old 10-08-2010, 08:09 AM
Village Troll
SS RRR's Avatar
A wire wheel? Please do not do this. Solvents are great, straight edge razor blade works. I've always used a plastic scouring pad, straight edge razor blade and brake cleaner.
That wire wheel is fine for the block as long as you keep it away from the pistons.
Old 10-08-2010, 08:24 AM
STOCKTA's Avatar
OVEN CLEANER OVEN CLEANER OVEN CLEANER
After getting sick of sandblasting intakes then having to thread tap clean all of the debris's out I tried oven cleaner. This is after I even tried soaking intakes in a parts cleaner full of pure diesel fuel with not much luck. I will never use brake cleaner or any solvent ever again, this stuff just melts off the sludge.
Old 10-08-2010, 08:43 AM
whytryz28's Avatar
Will try this out
Old 10-08-2010, 08:52 AM
speed_demon24's Avatar
Gasket remover dissolved the carbon on my pistons.
Old 10-08-2010, 09:07 AM
Matts94Z28's Avatar
Aluminum wheel cleaner works great.
Old 10-08-2010, 03:43 PM
brucer's Avatar
eagle one aluminum wheel cleaner or wd40 and a scotch brite pad..
i use a 90degree grinder and hit the valves with the little scotchbrite pads on the grinder, then i take a piece of sand paper and knock down the sharp edges on the combustion chambers..
Old 10-08-2010, 03:45 PM
brucer's Avatar
you could always try flying insect repellent and gojo hand cleaner .. LOL check out the picture
Old 10-08-2010, 04:32 PM
WS Sick's Avatar
If you use oven cleaner make sure to oil the moving parts afterwards, oxidation sets in real quick after oven cleaner.
Old 10-08-2010, 04:43 PM
z_speedfreak's Avatar
eh I brought em to my machinist and had him blast em for me, I brought him a 6pack but he didnt want any money so I slipped a 20 under his calender/schedule thing.
good tip I know lol
Old 10-08-2010, 06:13 PM
hashtagBMW
Speed Density's Avatar
I cant think of the name off the top of my head but its a gasket remover. It burns everything it touches, including skin/paint and works great for cylinder head cleanup. That along with break cleaner and you'll be squeaky clean.
Old 10-08-2010, 06:51 PM
Rockstar
Johnny-LT1-runner's Avatar
In my experience Purple Power instantly dissolved the grime and washed it away without any elbow grease needed.
Old 10-09-2010, 02:46 AM
monster81's Avatar
BBQ Grill Cleaner
Old 10-09-2010, 07:11 PM
94redz28's Avatar
I used purple power and a scotch brite roloc disc at low speed and it made easy work of the grime and carbon.
Quick Reply: Tips on how to clean up cylinder heads?
