intake manifold disassembley
Old 10-10-2010, 11:39 AM
LigHtEmUp01's Avatar
Default intake manifold disassembley
how do i take the fuel rails off and the injectors out? i noticed the injectors are in the fuel rail and then go into the intake. do i need to seperate the rail from injectors or do the injectors come out still attatched to the rail??
Old 10-10-2010, 11:44 AM
Village Troll
SS RRR's Avatar
Injectors can come out with the rail. I usually spray WD-40 in the injector bungs before trying to wiggle the rail back and forth. You'll just have to work it out slowly.
Old 10-10-2010, 09:19 PM
TheTransporter69's Avatar
I'm at the same part with my car right now, is it easier to pull the rails or to take the lines off? i got a 5/16 and a 3/8 disconnect but i don't really know how to use them. I think taking the rails out would give more access to the manifold bolts though. Do they just pop out or do you need to replace some seals or anything?
Old 10-10-2010, 09:29 PM
RamAir95TA's Avatar
When you remove the rails/injectors from the manifold, I would recommend replacing the injector o-rings. If they haven't been removed in awhile, the injector orings can "flat spot" making them unusable. They're cheap to replace and a good idea.
I always remove my manifold with the fuel rails/injectors still attached.
Old 10-10-2010, 09:55 PM
96capricemgr's Avatar
I believe if you get the Felpro intake KIT you get all the gaskets from the intake to head gaskets to the TB and EGR the silicon and the injector o-rings.
Old 10-10-2010, 11:43 PM
67goatman455's Avatar
put the disconnect tool on the lone. the thin part towards the clip. push the line in. push the disconnect tool into the line. pull the line off.
Old 10-10-2010, 11:44 PM
whytryz28's Avatar
Originally Posted by 67goatman455
put the disconnect tool on the line. the thin part towards the clip. push the line in. push the disconnect tool into the line. pull the line off.
That, took me seconds to remove both lines.
Old 10-10-2010, 11:54 PM
LSWHO's Avatar
If you look inside the connection of the fuel line there are little clips that keep the line from being pulled out. the tool pushes them outward so the line can be pulled.
Old 10-11-2010, 04:51 AM
Thanks for all the replies
Are you talking about the hard plastic piece that goes to the FPR? Theres like a rubber hose over a harder plastic hose.
Old 10-11-2010, 07:13 AM
RamAir95TA's Avatar
He's talking about the two fuel lines (feed and return).
Old 10-11-2010, 09:20 AM
Village Troll
SS RRR's Avatar
Doesn't it make it a bit of a pain to reach certain manifold bolts?
Old 10-11-2010, 09:34 AM
i know that but when i was looking at them last night they are like a hard plastic line over the metal line of the fpr, and theres like a rubber 7/16" hose over that. Maybe ill have to go look at it closer when i have time.
Old 10-11-2010, 09:38 AM
Village Troll
SS RRR's Avatar
Do you mean this:
You need this:
A/C/Fuel disconnect tool. It can be bought at any parts store. The next to the smallest size (can't remember what it is) will work to disconnect both lines.
Old 10-11-2010, 09:41 AM
RamAir95TA's Avatar
I don't recall having a problem. Then again I used a wobble extension in some places. I suppose it's more of a personal preference really.
Old 10-11-2010, 09:42 AM
Village Troll
SS RRR's Avatar
Originally Posted by ramair95ta
i don't recall having a problem. Then again i used a wobble extension in some places. I suppose it's more of a personal preference really.
ur doing it rong1111
I say we consult the great LSWHO for such a predicament.
Old 10-11-2010, 10:02 AM
RamAir95TA's Avatar
But but but but I don't want to be proven wronggggggg.....
Old 10-11-2010, 10:12 AM
wrd1972's Avatar
Old 10-11-2010, 01:02 PM
yeah ill have to look at it again, there's like 90 degree things on the fpr. If i have any more problems ill be back on here with pics or sumthing. These are the tools i got http://www.matcotools.com/ProductImages/ads394.jpg they are just 1 piece plastic things. Do those work right for this?
Old 10-11-2010, 01:28 PM
RamAir95TA's Avatar
Those are the same ones I have. They work good.
Old 10-11-2010, 03:41 PM
ok i finally got it, i was trying to use it after that 90 degree sweep thing that was the problem, they come off in like 2 sec when you do it right haha. thanks for all the help guys, my intake manifold is off!
Quick Reply: intake manifold disassembley
