What valve stem seals do I go with?
Old 10-10-2010, 06:37 PM
whytryz28's Avatar
Default What valve stem seals do I go with?
I have an ebay coupon so I want to get them on ebay.
http://cgi.ebay.com/ebaymotors/Viton...item588a03072d
http://cgi.ebay.com/ebaymotors/New-M...item27b38caf7a
Thanks
Old 10-10-2010, 09:04 PM
pro94lt's Avatar
I swapped out valve springs this summer because I thought my hotcam springs were floating, used the ebay valvesprings and I think a set of those, don't remember which one but they came loose pretty quick, don't know if it's those seals or the ebay spring which is a double spring which might have rubbed the seals. needless to say replacing valve seals in a lt1 with the heads on the car is my least favorite thing I've ever done. get some felpro they worked real well for me and never came loose.
Old 10-10-2010, 09:26 PM
RamAir95TA's Avatar
Felpro Viton seals. Avoid the K-Line "wiper" seals at all costs.
Old 10-10-2010, 10:48 PM
merim123's Avatar
check your valves and guides for size before you order the seals. you'll need to know what size they both are to get the right seals.
Old 10-10-2010, 11:34 PM
whytryz28's Avatar
Heads are off the car, they are stock LT1 heads off a 93
Old 10-11-2010, 06:52 AM
RamAir95TA's Avatar
Still check the OD of the guides and compare them with the new seals, just to be safe. IIRC, some manufacturers offered some funky seal diameters that claimed they would fit but did not.
Old 10-11-2010, 07:38 AM
whytryz28's Avatar
Will do, thanks.
Old 10-11-2010, 08:50 AM
Speedy's Avatar
Originally Posted by whytryz28
I used those light blue viton ebay seals and they are fine. They are slightly looser fit than the Felpro, so I was a little worried at first, but they have stayed put and done their job for 1500 miles, which is what I have on my rebuild. The color looks cool on an engine too.
Old 10-11-2010, 06:28 PM
spudnick3119's Avatar
FWIW, the inner diameter of the seals I used measured .55" and fit perfectly, nice and snug. Those .5" in your first link are way too small and won't fit on the stock valve.
Quick Reply: What valve stem seals do I go with?
