LT1 383 Blower Build
POST 140....Dyno Results!!!
This will be my official build page for the rebuild of my 97 Trans Am. The engine that was just pulled was a stock shortblock with a a head/cam nitrous setup. It ran well but I figured its time to step it up.
FOR SALE THREAD : https://ls1tech.com/forums/parts-cla...l#post14095702
I will keep this updated as often as I can. The goal is to have this ready by Spring.
Engine:
383 LT1 4-bolt splayed mains
Forged JE -31cc Blower Pistons
Forged Callies Dragonslayer Crank
Forged Callies 5.7 Rods
Custom LE Blower Cam
Trickflow 21 deg heads - Worked by LE (ported, polished, new valves, dual springs, etc)
Ported LT1 Intake by LE
Computer:
EFI Connection LS1 PCM Conversion
Blower:
Procharger F1-A 12-rib race system
Race Open Bypass
Trans/Clutch:
McLeod Street Twin
Built Trans (unsure of vendor at the moment)
Fuel:
Twin In-tank Walbro setup
80lb High Imp. Injectors
The new goodies
Engine:
Computer:
Blower:
Race Open Bypass
Trans/Clutch:
McLeod Street Twin
Fuel:
The new goodies
Thanks Jason! Good luck with your build.
69GTO - looking to run about 15lbs of boost. Should put me in the 650-700+ rwhp range is just my assumption based on similar builds. I chose the F1 just because if I ever wanted to kick things up more, the F1 gives me plenty of room to grow.
Thanks man. I'm pretty excited.
Thanks. I'm actually feeling pretty good now that everything is pretty much apart. I have a lot of new stuff so hopefully everything will come together since I've literally researched the living crap out of this build to have it come together as smoothly as possible. Time will tell.
F1-A is a direct bolt-on from what I understand.
.200 .300 .400 .500 .600 .700
146 206 252 289 301 304
108 145 179 207 217 226
The F1/F1-A isn't a standard kit offered by ATI. It's a "race" kit not even really talked about in their product brochure. I bought my F1-A setup used, but I'd assume most components are from a D-1 kit, with a few differences for the F1 race kit (different pulleys/rib count [mine's a 12 rib], tensioner, etc).
I'm thinking of putting the 4.25 pulley on mine while the motor is out, just so I'd get to 15 psi a bit earlier in the RPM's and have a slightly higher max boost..however, I'm not sure what "slightly" could mean! 18-20 psi probably. Not sure if I want to push it that far, but it would probably net 700+ at the wheels.
Maybe I should just settle for 650 and call it a day.....
