Race Converters.....
I am running a Precision Industries converter in my TH350 and always liked it. If I have to swap converters to run N/A then I would look at ATI, Neal, FTI but it's your choice. Later
Yea i've heard really good things about Coan too.....
absolutly i agree....it looked cool but i was cringing in the burn out box right behind you when you yanked em the first time.....once...sorry twice was enough lol
My dad runs a Coan converter in his th400 behind a 800hp pump gas 540 bbc... FTI is pretty big in the drag world aswell. Not sure if you seen the thier converter that bolts together... you can easily change internal parts to get the correct stall and str for your setup. Might be something to look into! It's kind of spendy tho...
just thought I'd throw it out there that my coolant temps on the freeway in 50 degree weather have been about ~200. 70 degree weather was ~209. So far even with the spragless converter I'm only running about 150-160 degree trans temps, with two big B&M coolers in front of the radiator. Mounting the coolers elsewhere will drop the coolant temps I'm sure though. Looks like the converter is looser than 5200, probably more like 5500-5600. I really think I'm going to have problems when it gets 90+ degrees, but we'll see. This is stock radiator & fans, CSR waterpump, and the block has a half-fill.
