Valvetrain Set up bad?? Ideas?
Old 12-01-2010, 11:17 PM
Purple94Z28's Avatar
Default Valvetrain Set up bad?? Ideas?
Okay so over the summer i built up the top end of my LT1 with p/p heads, crane springs, scorpion 1.6 rockers, and a cc305 cam. My friend at the local machine shop helped me do most of the install (hes also the one that did the heads). Okay so me and one of my Ltx buddy's here in Michigan were talking about how loud my valvetrain is and we were trying to diagnose it...well when my machine friend helped me measure for pushrod length he measure for a 7.00" length rod...well after we got them and started to set lash we realized the lock on the rocker would bottom out before lash was set so he just had me order lash caps...well me and my Ltx buddy were talking and he said he has never heard of a 7.00" length rod being used on an Ltx car..and when i asked my machine shop friend he said having the geometry of the valvetrain lower is safe on the motor and it will last longer. Well i think he was giving me a load of crock sh*t. And since this i have readjusted lash a few times and it never gets quieter (sounds like a rod knock, i can hear it over my exhaust and i have lt headers through a 3" y-pipe with a dynomax bullet dumped right after). I have a few questions for some true Ltx builders. Are my pushrods to short? If they are do you think they are robbing me of HP? Also do you think my scorpion rockers are not good? Should i have gone with comp pro mags? Any help would be greatly appreciated guys! Thanks in advance!
Nick Kerns
Old 12-01-2010, 11:22 PM
RamAir95TA's Avatar
There are several things that affect pushrod length, including deck height (both block and heads), head choice (stock casting or aftermarket) and head gasket thickness. Unless you've taken some serious material out somewhere (it doesn't sound like it) then your pushrods are WAY too short.
To put it into perspective, I have a zero-decked block, healthy milled heads (-52cc), and an .028" gasket and I use a 7.10" rod (which is still a bit on the short side). It is true that a shorter pushrod is a bit better than being too long, but that applies for about .05" of an inch.
How exactly did he measure for the right length?
Old 12-01-2010, 11:29 PM
He used his pushrod length tool...and yea i have stock replacement head gasket no decking or milling on the heads or block. I knew something wasnt right...i mean my ltx friend has milled heads and thinner gaskets and his are still like 7.10" i think. His car is the main reason i didn't really think he was right.
Thanks for the help!
Old 12-01-2010, 11:45 PM
RamAir95TA's Avatar
No offense to him, but it doesn't sound like he knows how to use it, or is using the wrong one.
Old 12-01-2010, 11:49 PM
Haha i think im figuring this out lol...thanks again for your help...i think im going to upgrade my cam to the ai 226/234 and get the correct length rods over the winter...btw man i love your car!! i cant wait till i build a 383 for my car.
Old 12-02-2010, 12:31 PM
AChotrod's Avatar
Agreed. Im thinkin they are way too short.
Old 12-02-2010, 12:48 PM
LSWHO's Avatar
Why don't you pull the valve cover and a rocker arm, cover the valve tip in magic marker, tighten the rocker down, spin the motor over once or twice and take a picture of the tip after that so we can see.
Old 12-02-2010, 02:11 PM
gjohnsonws6's Avatar
What size spring? Are they the narrow body version(self aligning) Show us a picture of the pattern on the valve tip.
Old 12-02-2010, 02:44 PM
litch2004's Avatar
Agree as well my heads are milled with .028 gaskets and ls7 lifter and I'm using 7.1 as well. Defiantly to short.
Old 12-02-2010, 03:43 PM
Would haveing guideplates installed on the head w/o them being milled down for them do anything?...also im using the stock rocker arm studs...?
I have ls7 lifters too...
Old 12-02-2010, 04:12 PM
old93camaro's Avatar
If you have guideplates on your heads then you better make sure you are not running SA rockers
Old 12-02-2010, 04:16 PM
RamAir95TA's Avatar
You cannot use self-aligning rocker arms with guideplates. Coupled with a pushrod that is WAY too short, you're looking at some serious trouble.
Old 12-02-2010, 04:18 PM
They are nsa rockers sorry i didnt post that
Old 12-02-2010, 04:21 PM
RamAir95TA's Avatar
You said you're running stock rocker arms...stock rocker arms are not NSA. Which one is it?
Old 12-02-2010, 04:23 PM
I mean rocker arm stud oops sorry i just cought that sorry...i have scorpion 1.6 nsa 3/8 rockers on my car
Old 12-02-2010, 04:24 PM
lol maybe he meant studs, rocker studs. And if you are using the stock 3/8 studs (maybe to late now) if i was you i would have went with 7/16 studs with 1.6 rockers. By the way i'm running the scorpions rockers and love them, cant here them for the life of me.
Old 12-02-2010, 04:32 PM
LSWHO's Avatar
Quote myself.
Old 12-02-2010, 04:36 PM
Quote myself.
ill see what i can do but its in a storage unit on the other side of town barried for the winter...
Old 12-02-2010, 04:56 PM
LSWHO's Avatar
Originally Posted by Purple94Z28
winter...
What is this "winter" you speak of? It's 78 degrees here.
Old 12-02-2010, 05:14 PM
It is a horrible time of year when only 4x4 and crappy fwd cars roam the streets =(
HAHA!! Lucky!! its 29 degrees here in Saginaw, Michigan and it was snowing today...and there is still snow on the ground lol
Quick Reply: Valvetrain Set up bad?? Ideas?
