Cam Thoughts
Cam Thoughts
Alright so I want to put a cam in. Im not sure what type of cam I want. I do know I dont want to spend a lot of money but i dont want to spend to little. I have been looking in the the Hotcam. But i have heard from people its really not worth the money. I have 53,000 miles on my lt1. Any suggestions? Im looking for more of a street drivability and it is my DD.
I want at least 350rwhp just for awhile nothing more mothing less.
I would look into something like a CC503. Lloyd Elliot or Advanced Inductions will also make a great cam for your stock heads/bottom end motor. I'd pick like a 228/232 on 110 LSA and .580 ish lift. More duration than that wont be ideal for your bottom end and less duration likely wont make the most power. They may suggest something slightly smaller, but I'd want something that size..
For a budget.. You can find cheap valvesprings on ebay for up to .600 lift I think, one of forums cam guide has a link to cheap ones also. Proform 1.6's or comp magnums on ebay well under 200. With those miles, there's a chance you can reuse your lifters, but new ones can also be had on ebay for around 100. I would buy a push rod length checker (like 25 shipped) so you can ensure the right length. Most brands will be fine in the right length and application, just shop around.
Hate to press in but-
What is the cc503 like to drive with stock heads? Is the torque curve significantly increased over the stock cam low down? Like, how would it be to drive around on a regular basis if you're not spinning the car up to 6k.
