Fuel Rail Leaking.... HELP!!!
Ok. So now I have got literally everything back together (Head gasket repair)... I turn the key to the "on" position to prime to fuel rails, and fuel starts spraying out of the hose that crosses over the front of the intake that connects the Driver side/passenger side fuel rails?
What is this part called?
Thinking bout buying a new one.
Pic attached
Pic attached
Are you guys sure were talking bout the right thing?
I have to buy new rails to fix the leaking hose...
http://www.summitracing.com/parts/EDL-3620/
Those rails dont come with the hose?
http://cgi.ebay.com/ebaymotors/94-97...Q5fAccessories
Thats what your looking for, there's a few on ebay
Then its probably just bent. Pick up a new o-ring and make sure the brackets are square when you put them back on.
Wiggling/forcing the rails and injectors in normally bends one of the brackets that holds the tube on and causes a leak. I had the same issue a while back.
I can't say for sure, but I do think injector o-rings will fit. I just bought a multi pack at AZ so I can't say for sure.
You aren't missing a bracket, its the rusted thing below the bolt that holds your rail on in your pic. They goes on sideways (4 of them) and hold the tubes to the rails. Just drain the tube of gas and remove the brackets with a torx head. Bend them back to square and reinstall.
