Forgot something on cam swap
Old 12-22-2010, 09:10 AM
SPOT ME 3's Avatar
Question Forgot something on cam swap
I forgot to put the relucter ring back on during my cam swap yesterday, and everything is sealed and torqued down. Doing away with emissions, so can I just use an obd1 and get it flashed from a mail order tune? I DO NOT want to tear back into it!! Any suggestions?
Old 12-22-2010, 09:43 AM
damn's Avatar
Damn i feel your pain!! But i cant offer any advice because i dont know what the ring does the proper thing would be to put it back im sure.
Old 12-22-2010, 09:57 AM
speed_demon24's Avatar
If you want your timing chain to last you will put it back on.
Old 12-22-2010, 10:07 AM
quik95lt1's Avatar
reluctor ring???? u talking about the retaining ring with the two torqs head bolts that hold the cam in the block??!!
Old 12-22-2010, 10:17 AM
Sounds like he's talking about the crank sensor to me.
Old 12-22-2010, 10:50 AM
quicksilver383's Avatar
If indeed you are talking about the wheel for the crank position sensor it will affect a couple of things.
Your crank position sensor will throw a code with the OBD2 PCM. But, it might anyway if your cam is lumpy enough.
Your bottom pulley/balancer will not line up perfectly with the other pulleys. The hub will tighten down against the lower timing gear even without the wheel there. How bad your pulley alignment will be off will depend on how thick that gear is. A double roller will be almost as thick as the single roller with the reluctor wheel like the original set up. I run a Cloyes double roller and made a spacer to make up the difference but I know of others who have just run without it using that chain. The spacer is tiny, like a hair over a 1/16" IIRC.
If your running the single roller you can make a spacer the exact width of the reluctor wheel or I think you can just use an OBD1 car's hub.
Old 12-22-2010, 10:51 AM
SPOT ME 3's Avatar
Yep-crank sensor. I heard obd1 cars don't have them - just 96-97 obd2
Old 12-22-2010, 11:00 AM
SPOT ME 3's Avatar
Cool! Many thanks! I don't see how leaving it off would affect the life of the chain. I used a stock replacement though. If I had a new engine it would be a nice dual roller.
Old 12-22-2010, 11:21 AM
AChotrod's Avatar
I would pull it apart and put it back in
Old 12-22-2010, 12:36 PM
Verz's Avatar
agreed, its a couple hours work at most and some new gaskets
Old 12-22-2010, 01:06 PM
speedracer2536's Avatar
for real.. you will need a new tune on that obd1 pcm as well.. not worth it..
Old 12-22-2010, 03:32 PM
defaultexistence's Avatar
D to the power of 3
Old 12-22-2010, 05:21 PM
SPOT ME 3's Avatar
It's gotta have a tune anyway, so screw it - I'm not looking back after ripping my front oil pan seal and the water pump shaft seal during the install. I know what you guys are saying about the love-hate LT1's now!
Old 12-22-2010, 06:04 PM
you should prob sell you car......
Old 12-22-2010, 06:22 PM
BlackBird87's Avatar
extra parts? nahhh **** it'll be fine
Old 12-22-2010, 06:28 PM
RamAir95TA's Avatar
The love-hate is almost ALWAYS because of a lack of understanding by the owner. Thank you for personifying that.
Old 12-22-2010, 07:47 PM
Wyocattech's Avatar
Ah the damage its gonna cause with out it is no big deal. Its only money right
Old 12-22-2010, 10:00 PM
SPOT ME 3's Avatar
Cmon guys- it's not that big of a deal what I missed. If it was the thrust plate, I'd go back and make it right. Emissions can go in the trash. Wouldn't doubt that I can still use my obd2 and get the sensor tuned out. Get myself an earlier crank hub and it's go time.
Old 12-22-2010, 10:14 PM
Wyocattech's Avatar
Prolly cost more in the long run for the crank hub and tune then to take the couple hours to put it back in.
Old 12-22-2010, 10:18 PM
SPOT ME 3's Avatar
Btw...I LOVE LT1's and this forum for all the great cars and owners who have had the highs and lows of working on ANY motor.
Quick Reply: Forgot something on cam swap
