Rim size and backspacing
Old 12-24-2010, 04:30 AM
ls1adamls1's Avatar
Default Rim size and backspacing
im in the market for some drag rims and was curious
if i go with a 15x10 what BS would i need
and if i go 15x8 waht would the BS needed.
correct me if im wrong but,
15x10 would need 7.5 BS or would a 6.5 work?
and 15x8 = 5.5 BS ????
Old 12-24-2010, 05:01 AM
red93z28lt1's Avatar
depends which is more availible to you? are you going to have to go out of your way to get one of the sets more than the other?
Old 12-24-2010, 05:05 AM
ls1adamls1's Avatar
no either size is available, just wanting to be sure i have the rim size to bs correct
ls1adamls1's Avatar
also ill probably be running a 28x10x15 inch tire
Old 12-24-2010, 07:08 AM
stevo9389's Avatar
a 15x10 with 6.5BS would probably stick out too much for you (and probably have rubbing issues on the fenders depending on ride height). myself and everyone else i know stick with the 7.5BS. and yes a 15x8 would be a 5.5BS for our cars.
Old 12-24-2010, 05:39 PM
ls1adamls1's Avatar
cool thanx for the help
Old 12-24-2010, 06:08 PM
ls1adamls1's Avatar
anyone know the center bore diameter of our cars?
Old 12-25-2010, 09:54 AM
Miller95z28's Avatar
15x10 with 6.5 backspacing, tucked 28 10.50 undermy car under the fenders easy
i run a 15x8 with 4.5 back now and if you look hard it fluch with side of car not tucked but still lets susp. travel and no rub
Old 12-25-2010, 10:28 AM
MattSapp95_T/A's Avatar
Mine are 15x10 with 6.5 BS
I don't have any problems with them rubbing or anything either..and I like the deeper dish on the outside of the wheel..
Old 12-25-2010, 10:30 AM
And this is with a 10" slick
Old 12-26-2010, 02:39 AM
ls1adamls1's Avatar
first off lemme say you have a beautiful car!!!!
and those wheels do look good but im looking to tuck them alittle more.
i have a set of 15x8 with a 4.5BS and they stick out too much
they fit just like the ones in the pics
Old 12-27-2010, 01:38 AM
ls1adamls1's Avatar
ok so i have the rears figured out
so if i was to run a 15x4 up front what would the bs need to be? 1.75?
Old 12-27-2010, 07:27 AM
Thanks!.....You will want to go with a 15x10 w/ 7.5 BS or 15x8 with 5.5 BS
Just don't get really wide tires like 325's or they will stick out worse than mine even on the 7.5 BS
Yes 1.75 will work fine
Old 12-27-2010, 10:49 AM
Bullit95T/A's Avatar
Do you got any pics of your car from behind ??? i like the look of the 6.5 back spacing
Old 12-27-2010, 12:46 PM
Here you go... with MT ET Streets
This is a camaro with 7.5bs (and one of my favorite camaros on this board...Matt PM me if you don't want this pic used)
now you can see them back to back....
Old 12-27-2010, 05:49 PM
Wicked94Z's Avatar
7.5 unless your rear is narrowed, those 6.5 bs wheels above stick out way too far. you can clear a 28x10.5 easily on the inside wheelwell with a 7.5" bs and the tire will actually tuck inside the wheelwell. My car is LOW and the tire sits 1/4"+ up inside the wheelwell, couldn't do that with a 6.5".
Old 12-27-2010, 05:56 PM
SexyTransAm's Avatar
really 490 posts and you dont know how do use the damn search button or post in the right place
Old 12-27-2010, 07:48 PM
Never had a prob with mine clearance wise...the tires do not stick out past the rear quarter panels.. Then again I don't have my car lowered like and import either...
Old 12-27-2010, 08:53 PM
Wicked94Z's Avatar
LOL why'd you take down those beautiful rear end pictures??
This import inspired ride went 1.45 60' on it's 3rd pass, with something like a 6.8:1 A/F on the stock rear sway bar. Clearly I should jack my car back up and put the wrong backspaced wheels on it to improve
Old 12-27-2010, 10:16 PM
LOL Well I would sure hope so with a 5600 stalled auto with 4.71 and a 389 stroker motor with aftermarket heads you would 60' in the 1.4s....
And I didn't take the "beautiful rear end pictures" down I was putting up another picture so people could see the difference....
Anyways for the OP this is a picture of my buddies car that has 7.5 Backspacing so you get an idea of what the difference is... A lot of Trans Am guys run the 6.5s however Camaros don't tuck them as well...
Another TA with 6.5 BS its really just a personal choice they both will work fine..
Quick Reply: Rim size and backspacing
