cc306 install need help
Im doin a cc306 install this winter and I just want to make sure I got all the right stuff. Motor was recently rebuilt and has around 3,000 on it with arp rod bolts, new steel chevy rods, and was balanced but other than thats it was pretty much a stock rebuild.
Patriot spring kit
611-16 comp locks, got them for christmas..(or do I need the .050 locks??)
ls7 lifters
Pormags 7/16th 1.6
ARP 7/16th studs
Guide plates
Hardened pushrods
EWP
Gasket kit from thunder racing
Lmk what you think, thanks for the help!
Patriot spring kit
ls7 lifters
Pormags 7/16th 1.6
ARP 7/16th studs
Guide plates
Hardened pushrods
EWP
^^I agree with this. You will also need bigger injectors such as 36# and a tune. You will get alot of people telling you there are far better cams out there than the 306, and there are. Dont let them sway you just because they dont like the 306. I have it and i love it. It may be old tech but it is a proven cam.
Thanks guys I will definately keep the injectors in mind. I will prolly have them done after I get it dynod. As far as the timing chain it only has 28,000 miles on it and we reused it when my engine was rebuilt 3,000 miles ago, it wasnt stretched at all. Should I still do it just incase?????? And ya im stuck on the cc306 despite what everyone says I really want to proove this cam can get it done.
Also anyone with a cc306 can I use the 611-16 or do I need the .050 locks I heard this cam could go into coil bind???
Thanks for the help
Thanks for the help
Thanks for the help
Thanks for the help
Awesome thank you so much guys. I will just use the locks in the patriot kit then. I just got these 611-16's for christmas and wasnt sure if they were the same as the ones in the patriot kit?? but I think they are...O well I can just sell them to a buddy or somethin.
Decided to bump this, need some advice/help. What are the best guide plates to go with?? I have heard alot about iskys or trickflows does anyone have a part numbers for these, or a link?? I need to place an order for some this week. Thanks for the help!
Also what color loctite am I suppose to use on the 7/16th studs??
