Power Steering went out?
Old 01-13-2011, 09:49 AM
transamws6_97's Avatar
Default Power Steering went out?
Well I ended up getting my car basically trapped on the side of the road bcs the plows had pushed snow and it built up to basically the bottom of my door so it took me 20 minutes to get out so I could go to work. In the process of getting out my ps went out and now its really hard to turn the wheel but it can be turned when you put some force to it. I checked the reservoir and it was dry so I ran down the street to autozone and bought a bottle...filled up the reservoir and and the ps worked for about 10 seconds then it stopped working again and the reservoir was dry again and i saw fluid all down the passenger side wall and equipment near the pump. So I'm thinking the pump went bad or a line broke somehow and I need to look at it when I get a chance but do I risk damaging anything by driving with the system dry and not operational?
Old 01-13-2011, 01:04 PM
iWon's Avatar
Well if the pump is still good and a line is bad, then yes you will damage the pump by driving it dry.
But if the pump is already bad and that's what's leaking, then there is no more damage to be done. You need a new pump.
Try and find where the leak is coming from and go from there
Old 01-13-2011, 01:50 PM
yeah thats what im gonna do when i get back from class today...just sucks when i could be at home in a warm dry garage checking this when im at school in an apt so ill be having to figure this out in the snow and wind and its freezing outside.
Old 01-13-2011, 02:20 PM
96azz28's Avatar
just move to AZ and you wnt have to deal with snow =) lol
Old 01-14-2011, 09:39 AM
tricked94camaro's Avatar
ive broken a line before but it was the high pressure one and cost me $45
Old 01-15-2011, 03:00 PM
ok well i went out and put more fluid in it and ran it w/ the hood open to see if i could find out where the leak is coming from...its leaking where the hardline connects to the pump from the lower passenger side of the pump...so my guess is either the hardline needs to be tightened or theres a hole in the hardline
Old 01-15-2011, 03:31 PM
what size wrench is needed to tighten the hardline?
Old 01-15-2011, 11:48 PM
RamAir95TA's Avatar
Really? Not to be an ***, but it's nothing special, nor is it hard to get to. Throw a couple metric wrenches on there and find out. I am sure that it's metric though.
If you can, use a line wrench. If you strip that bitch, forget it.
Old 01-16-2011, 02:54 AM
im not trying to be lazy but the fact is that im at school and all my car tools are back at home i have to go to autozone and buy a wrench just for this occasion so I dont wanna be buying a whole slew of wrenches when I have them at home.
Old 01-16-2011, 03:10 PM
bump...i really don't wanna have to buy a whole set of wrenches at autozone since i already have a set at home (3 hours away) but if nobody knows what size guess ill have to
Old 01-16-2011, 05:57 PM
eww dont buy autozone tools. at least get craftsman.
Old 01-16-2011, 06:09 PM
05HD's Avatar
I think it is a 16mm but I don't recall for sure.
Old 01-16-2011, 06:30 PM
Its just to use for this one time it'll prob end up getting thrown away at the end of the semester
Thanks a lot
Old 02-01-2011, 05:24 PM
marc1130's Avatar
did you fix it?
