LS1 lid swap is easy
Old 01-29-2011, 06:37 PM
bufmatmuslepants's Avatar
Default LS1 lid swap is easy
Started and finished the swap this afternoon. Easy. Did it a little different than I have seen done, by using the old radiator shroud and bolts. Shitty cell phone pics.
Before
Mocking up lid
Cutting lid so the inlet faces the throttle body more.
Cut the frame to fit the filter. Used a 4 1/2 inch cutting wheel and it was like cutting butter. Same with the hood but I didnt get any pictures of that.
Fernco coupling on the throttle body. Reused old radiator shroud.
Fitting in the filter
Done
Drilled holes for the IAT sensor and opti vent
It hits the hood a little bit, you can feel a little bulge when it is closed, but it holds the filter tight against the lid so I am fine with it. Next up is to fab up some sort of ram air effect from the front, then test it in the spring.
Total Cost:
Used SLP lid $50
Fernco 3" to 3" coupling: $7
K&N filter: $64
Beer: $10
Tools used
Hacksaw
Sawzall
Cutoff wheel
Drill
Old 01-29-2011, 07:25 PM
Badazz 97 TA's Avatar
looks like ***....what a mess
Old 01-29-2011, 07:34 PM
white ghost's Avatar
Well.....it looks ummm.......affective.....I guess...:gulp:
Old 01-29-2011, 07:35 PM
My whole car looks like ***, whats 1 more thing as long as it gives me hp
Old 01-29-2011, 07:36 PM
BlackBird87's Avatar
umm whats holding the filter tight to the lid
Old 01-29-2011, 07:37 PM
05HD's Avatar
So, you just flopped the air filter down on top of the radiator? Slamming the hood on the lid holds it together?
Old 01-29-2011, 07:39 PM
Pretty much, I followed this guys link.
http://joelrdevriendt.com/?p=46
I will put the little 1/4 inch screws in the front of the lid eventually, car isnt leaving the garage for a while.
Old 01-29-2011, 08:01 PM
Lawhead's Avatar
Eveyone said mine looked bad too man with the new build Ill make it look a lil better
but it worked so who cares right?
Picked up .15 and 1.5 MPH
Old 01-29-2011, 08:03 PM
you missing the entire part on using an ls1 radiator shroud
Old 01-29-2011, 08:08 PM
Lawhead's Avatar
I at least did that
Old 01-29-2011, 08:26 PM
93M6Formula's Avatar
I'm sorry, I couldn't just hack up my car like that. But i'm also a perfectionist...
Old 01-29-2011, 08:44 PM
AChotrod's Avatar
Gotta agree, good idea bad exicustion.
Old 01-29-2011, 08:50 PM
whytryz28's Avatar
You got it, thats how mine stays put.
Old 01-29-2011, 08:58 PM
borninatransam's Avatar
your spelling, much like this thread, is full of fail.
Old 01-29-2011, 09:13 PM
Lawhead's Avatar
If your going to call someone out make sure you don't look dumb yourself
Its spelled right just wrong word.......If we want to talk about fail
The word he was looking for was "effective"
Old 01-29-2011, 11:06 PM
SpeedFreak123's Avatar
OHHHHHHHH!!!!! LOL, good call, I'm buzzed and over looked that.
Old 01-30-2011, 12:01 AM
BigD383lt1's Avatar
but this is also someone who ported his maf and I am sure he is not getting anywhere close to the hp needed for that mod.
Old 01-30-2011, 01:42 AM
tricked94camaro's Avatar
damn ametuer
Old 01-30-2011, 03:08 AM
is that electrical tape that connects the maf to the lid
Old 01-30-2011, 03:21 AM
killagt's Avatar
TBH man, the before pix is look better then after pix. I would never chop my car out like that.
Quick Reply: LS1 lid swap is easy
