Looking for a Vic E
Did all the work in my own shop, no fancy tools or anthing. Then had the holes tig welded up and powdercoated the intake. Even built the top aluminum peice to accept the plenum ported intake as well as the monoblade. If you have time do it yourself, and Id start with a vortec Super Vic before that Vic E if your serious.
ok........mike i got the dizzy plug hole and bracket already done and im taking it off of mine so i can send it to u if u want it.........also if your going to have the machine work done i got a jig already built for a bridgeport from when i did mine..........all u do is bolt the manifold to it and square it up and level it on the bed and then line up ur hole spacing from the old intake........mine worked out great........
I lucked out and bought RamAir's already ported and modded Vic E efi intake and fuel rails then I got the Nitrous Outlet 860 elbow and the MSD sbc oilpump drive (plugs the distributor hole) and a ZEX perimiter N20 plate.
and idk about that vortec manifold........bad idea........i ordered one up to mock up and sent it right back.....
I'd take a larger runner/ larger plenum Super Vic over the Vic E on most apps.
I really like mine.
